Old November 2, 2008, 05:10 PM
matsta31's Avatar
Default Socket 1366
I am sure most of you knew that, but I stumbled on this when looking for other stuff, Nehalem adaptor for my trusty Fuzion...
Nehalem Socket B / LGA 1366 /Bolt-Thru-Kit with Screws & Springs
Sold hardware again.....
Currently using WHS hardware....
Old November 2, 2008, 05:12 PM
Xilikon's Avatar
It's just a backplate with screws and springs. It's not a adapter for the fuzion since the distance between two holes is not the same.
Xilikon - Team 33
Proud to be [H]ard !
