<~----> What are these things on a p5n32e sli plus - Hardware Canucks
Old October 31, 2008, 01:20 AM
odis172's Avatar
Default What are these things on a p5n32e sli plus
So i recently watercooled my cpu, and threw some swiftech mc21's on my mosfets. My question is what are these things in the picture, during some prime95, they are hitting 70degrees C, and the mosfets are hitting 60 (might throw some active cooling on em) Im considering cutting up some mc21s or if they fit span them across these little things whatever they are. Any clue?
Laptop: Lenovo T420 - Core i5 2520 - 8GB DDR3
Server: 2 xeon E5530 - Asus Z8N-D6 - 12GB DDR3 - 8x 500GB raid 50 - Perc 6/i - Compucase RA448A00
Old October 31, 2008, 01:21 AM
i'd say voltage regulators
Old October 31, 2008, 01:30 AM
odis172's Avatar
I googled voltage regulators, i think your right. "8 phase" that may explain why theres 8 of them?
Old October 31, 2008, 01:31 AM
Yup. Its normal for them to get toasty but if you water cool your going to want to add as much additional cooling to your case to cool them or put something on them to cool them.
Old October 31, 2008, 05:01 AM
Jackquelegs's Avatar
Those are voltage regulators, I would recommend under WC to attach a passive heatsink onto them, since some of them do run very hot
8 phase = 8 regulators.
Iapetos
Zephyranthes
Old October 31, 2008, 05:09 AM
Babrbarossa's Avatar
Throw some of these babies on- they work well
psst, wanna see my binder?
Old October 31, 2008, 07:50 AM
odis172's Avatar
Nice, i do have some of those laying around, ill do that. Thanks!
Old October 31, 2008, 11:13 AM
MpG's Avatar
MpG MpG is offline
Yeah, if you're pushing them hard enough that they're heating up, you should probably consider some passive cooling. Especially the CPU is water-cooled, which eliminates the airflow that a heatsink would normally create. Those ramsinks do a good job, but make sure they're secure - you don't want a piece of copper suddenly breaking off and shorting out something else. Thermal epoxy is nice, and if you cut it 50/50 with Arctic Silver 5, it can usually be carefully twisted off without any damage to the components.
Old October 31, 2008, 11:34 AM
Or you can get 50m of thermal tape at NCIX for attaching those pesky sinks
NCIX.com - Buy Sekisui Thermal Double Sided Tape Sekisui Product Code 5760 25MM (1IN) X 50 Meter Roll - SEKISUI-5760 In Canada.
Iapetos
Zephyranthes
Old October 31, 2008, 06:58 PM
Apollo4g's Avatar
I picked some of that thermal tape, want to see what all the hype is about :)
800D | i7 920 | EVGA Classified LE | 5970 EK Waterblock | 12GB - 1600 Dominators DDR3 | Silverstone Decathlon 1200W | Vertex 120GB |
ASUS Xonar HDAV1.3 | Heatkiller 3.0 | Thermochill PA.120.3 | Freezone Elite | 2x655's with EK Dual D5 Top | T-Virus Res |
