Old October 24, 2008, 09:04 PM
MpG's Avatar
MpG MpG is offline
Default MicroRes rev.2
Swiftech MicroRes revision 2
Not sure when it'll hit retail channels, but thing is seriously looks like the bomb. Anybody pricing out a WC system in the near-future may want to keep an eye out for this.
Old October 24, 2008, 09:12 PM
Very nice.. now that bottom port is a very nice feature.. Also instead of using those plastic caps they now use proper stuff.. Now you can install a barb on the top and use it for filling liquid, use the bottom as a direct connection to pump or drain.. I am liking this..
Thanks for posting, and priced at $25.95, still pretty reasonable.. I am buying this, it is perfect for my setup..
Old October 24, 2008, 09:18 PM
1/4 BSP fittings all around.
Hope they fixed the cracking issues.
Old October 24, 2008, 10:34 PM
Sniper's Avatar
Damn I was going to post this here to but got side tracked with the guys playin BF2 lol. ha
Old October 24, 2008, 10:40 PM
Iamcanadian7's Avatar
Ohh, very nice I like the new fittings as well as the drain feature. Not bad for $25 bucks.
Old October 25, 2008, 07:58 PM
biff's Avatar
- the plated barbs are listed as optional...
- Functionally more versitile than the original though it doesn't look nearly as clean.
- Not sure if you can 'fix' people over tightening barbs.
Overall some nice improvements that could be very useful depending on the build but I hope they don't phase out the original.
i7 4790K @ 4.8GHz w/EK Supremacy Evo
MSI z97 Gaming 5
2x 8GB Gskill Sniper 2133 @ 2400MHz
EVGA GTX 280 (SC?)
OCZ Gamer Xtreme 600W PSU
Still rockin' the Cooler Master Cosmos on water
Old October 25, 2008, 08:30 PM
Cracking issue.. I dunno, I've never had any, and I've put barbs in and out many times on that res.. Just like biff said "Not sure if you can 'fix' people over tightening barbs.".. You are probably over tightening the barb way too much, I don't even suggest using a wrench to tighten the barb
Old October 25, 2008, 08:50 PM
Lots of people have reported their micro-res to crack and have done nothing but use their system like anyone else.
It seems that whatever happened in the process of making them caused hairline fractures which overtime cracks the res.
There is reports of this on [H] and XS
Old October 25, 2008, 09:20 PM
Supergrover's Avatar
Well I will pick one up just for the bottom fitting, I do believe reading something about the cracking issue but cant comment for sure.
IDC if the metal fittings are optional.
Going to have to remember to grab a top and temp plug from Gary the next time I order.
R.I.P.
Old October 26, 2008, 05:39 AM
Xilikon's Avatar
Ys, I read lots of posts about that and even Gabe is a bit baffled about that. The most accepted hypothesis is that there are different grades of acrylic sheets and some of them is more prone to cracking due to temp stress (heating/cooling cycles around stress points). I guess they are fixing this right now.
I also love the new model, it's a great update which fix the v1 shortcomings. It's slighty more pricey but it's expected, especially if they bothered to pick a better quality acrylic sheet to build them.
Xilikon - Team 33
Proud to be [H]ard !
