Old October 21, 2008, 03:28 PM
Default Swiftech Rad fine?
Hay guys....
I cant for the life of me get my single 120 rad to stop leaking. Its mounted outside the case and I've tried tape, and silicon and noting seems to stop the slow trickle. To be honest, its not even worth mentioning because the leak is sooooo slow. Its like a single drop over a weeks period of usage.
BUt.... if I replace it. I would like to get a dual rad. I have minimal funds so my question is, are the 50 dollar swiftech rads perfectly fine for cooling 2 8800 gtx's or should I save up for the fesser or blakc ice ectreme rads?? Ill separate the loops, so the CPu willl be on its own, and the GPu's on the new one.....
Seems i save 50 bucks by going with the swiftech rad opposed to the other models out there...
thanks...
i2600k sandy bridge @ 3.4ghz/ 2x 8800 GTX KO ACS3 PCI-E 630MHZ 768MB 2.0GHZ SLI'd / Raptor 74GB / Antec 1200 Hundred Gaming Case / G.Skill Ripjaws ddr3 1600 cl 8-8-8-24 - 8gigs / evga z68 SLI MOBO / Samsung DVD+RW / Corsair ax850 PSU / 24" Samsung CinkMaster
Cooling:
Swiftech Dual rad
Swiftech Single rad
Swiftech Micro Res
Swiftech Apogee GT Cpu block
Feser One Red Fluid
Old October 21, 2008, 03:30 PM
JD JD is offline
A MCR220 would be fine I'd think for dual 8800GTX's though if you wanted lower temperatures, then go with the MCR320.
Old October 21, 2008, 03:49 PM
Cptn Vortex's Avatar
MCR320~!!!
The Vortex H20
MSI Z87-G45 Gaming
i5 4690K @ 4.5GHZ
SLI GTX 1070
12GB GSkill Ripjaws X 2133MHZ CL10
OCZ Z-Series GOLD 850W
HP OMEN 32 1440p 75hz
Benq W1070 Pojector.
Watercooling:
Old October 21, 2008, 04:29 PM
Sniper's Avatar
So you have another rad that the cpu is on then? If you have the space for the little bit extra money get the MCR320 but if you don't the best bang for your buck is the MCR220. I've learned quite abit over the last little while & the Black ice rads are only good with high static fans. 38mm at the least thick. Stick to the thinner swiftech rads or make the big jump(double the money) & go with thermochill but bang for buck wouldn't really be worth it.
Old October 24, 2008, 10:47 AM
Yes. Right now I have the loop of...
Dual rad, single rad, Cpu, Gpu1, Gpu2 rez, pump.
If I get the bigger rad then Ill redo the loop to this...
Dual rad, cpu, dual rad, gpu1,gpu2, rez, pump.
IM assuming I will only see a decrease in temps in my last gpu with the separate looped system and the dual rad.
If I got the triple, would I still do the second loop (in red)
Cooling:
Swiftech Dual rad
Swiftech Single rad
Swiftech Micro Res
Feser One Red Fluid
Old October 24, 2008, 12:12 PM
Synth's Avatar
Have you tired doubling up the o-rings on the barbs ?
I was having a similar issue, using Bitspower fittings on Swiftech components, and doubling up on o-rings fixed the problem.
Old October 24, 2008, 12:28 PM
Originally Posted by Cptn Vortex View Post
MCR320~!!!
Hey it is you Frosty!!...
There's you answer
Old October 25, 2008, 10:02 AM
hello hello!!! :)...
does anyone know if mounting a triple rad to the rear of any case causes a problem... the thing looks huge!!!!!
id be worried if it covers the inlet holes...... then what??? Or do I shift the whole thing up 1 fan spacing and use the rad box, mounting it to the middle fan and not the top? Id just have 1/3 of the rad sticking up above the case (basically take the photo and postion the rad up on complete fan spacing...). Would that look funny?
Cooling:
Swiftech Dual rad
Swiftech Single rad
Swiftech Micro Res
Feser One Red Fluid
Old October 25, 2008, 10:24 AM
3.0charlie's Avatar
That's my old 120 I sold you, and it never leaked. The only reason why it would is that you are using 90* elbows, and those may not be torqued enough to prevent any leaks - since you need them pointing down.
A second o-ring as suggested by Synth would work.
John
Hydro-Quebec is salivating...
Old October 25, 2008, 10:29 AM
magictorch's Avatar
Youll be fine mounting it to the top rad box, you can mount a couple of brackets to support the bottom of the rad. Also have you looked at Frankys rad mount-he used brackets to mount the radiator at the back of the case at a 90 degree angle to the exhausts.
I borrowed this idea for mounting my triple as well, also have a 220 bolted straight to the exhaust- 2 rads at the back-could do with a bigger case.
