Originally Posted by MpG You're saying that if the radiator was a cm shorter, it would fit inside the case?
How hard are you pushing this rig? How high are you clocking it? If you're doing something like folding, you could quite possible push both procs and both GPU's to near 100% steady, which will could easily mean over 600W of heat needing to be dumped by the radiator.
How much noise are you willing to put up with? How high do you want to clock this rig? |
I'm stuffing all this into an NZXT Rogue, aprox 36cm inside from end to end. (working out of town, cant measure) so even if the length works, I'd still have other things to consider.
My goal is 4ghz+, and yeah it will fold, perhaps not 24/7 (depends on heat and noise).
My big obstacle is actually time, I'm barely home and usualy have more pressing things to get done before going off to the next job.
