Old October 14, 2008, 07:26 PM
Sniper's Avatar
Default Bolt through kit for EK Supreme
Anyone using this cooler? Wondering what I should get for a bolt through kit & where. I really haven't seen anything at NCIX for this. Unless i'm overlooking it? lol
Old October 14, 2008, 07:40 PM
JD JD is online now
There's less restrictive blocks out there they are pretty close in performance that you might want to look into instead.
As per a bolt-through kit, it already is. Just that it doesn't use a backplate I believe.
Old October 14, 2008, 08:04 PM
Sniper's Avatar
K I've heard good things about the block. I have the back plate ordered just wasn't sure about the bolt through kit. I refuse to use pushpins ever again.
Old October 15, 2008, 04:24 AM
Xilikon's Avatar
I never ever saw waterblocks using pushpins. The only exception is the D-Tek Fuzion v1 quick installation kit which use push-pins as a option...
Xilikon - Team 33
Proud to be [H]ard !
Old October 18, 2008, 09:04 PM
Linus's Avatar
The Alphacool NexXxos XP Lite also used push pins, as does the Asetek LCLC
Old October 19, 2008, 05:44 AM
Xilikon's Avatar
Oh, I'm learning something today
Xilikon - Team 33
Old October 19, 2008, 06:02 PM
Sniper's Avatar
Heheh thx Linus! I found out it comes with it's own non pushpin kit lol. Order will be put through next week now finally!
