Old October 14, 2008, 02:25 PM
Sniper's Avatar
I beleive he's running 3/8 barbs.
Old October 14, 2008, 03:04 PM
Dr_BenD_over's Avatar
Fallen Folder
3/8"
filler...
All's well that's Haswell
Old October 14, 2008, 05:18 PM
biff's Avatar
Originally Posted by lcdguy View Post
If the barbs have a oring nothing is necessary. Vaseline will make it easier to take apart down the road.
FWIW, the vaseline will help the o-ring seat itself a little better. If the block (or whatever) is a little sticky to the rubber and the barb as well then it will stretch and twist the o-ring slightly, as in VERY slightly, as it is tightened but it could be enough to cause a slow drip. I agree it shouldnt be necessary but it doesn't hurt.
i7 4790K @ 4.8GHz w/EK Supremacy Evo
MSI z97 Gaming 5
2x 8GB Gskill Sniper 2133 @ 2400MHz
EVGA GTX 280 (SC?)
OCZ Gamer Xtreme 600W PSU
Still rockin' the Cooler Master Cosmos on water
Old October 14, 2008, 05:23 PM
Xilikon's Avatar
I would not mix vaseline with o-rings since the petroleum jelly will eat rubber alive.
Xilikon - Team 33
Proud to be [H]ard !
Old October 14, 2008, 06:46 PM
magictorch's Avatar
Yes petroleum based Vaseline is not good with rubber although something like KY jelly is fine.
Old October 20, 2008, 03:47 PM
Sniper's Avatar
Overclock.net - Overclocking.net - View Single Post - Info: Using teflon tape.
Old November 1, 2008, 09:28 AM
kirk_d's Avatar
If you find teflon tape is necessary, be very careful with it. If it gets into your pump, or worse yet the rad, you'll have big trouble.
Opty 170(naked) @2600 | Abit AT8 32x | EVGA Vanilla 8800gt 650/1625/950 | 2gb Ocz Pc4000Eb@260 | Audigy Gamer | Tx650 | Cm690 |
WC Loop: DD Cpx-Pro | HWL 240 Xtreme | D-Tek V2
