I noticed these on sale in the Sponsered sales. Bitspower G1/4 Straight Compression Fittings How exactly do these work?
__________________ "Though I walk through the shadow of the Valley of Death I shall fear no evil as my M4A1 Carbine is locked and loaded." - Rigless [Heatware] BALISTX.com |
That is the size of tubing that I plan on going with. So the compression fittings take the place of the barbs and the hose clamps then. Would you say these are more secure than the barb & hose clamps?
| Quote:
__________________ Xilikon - Team 33 and top 100 worldwide in Folding @ Home Proud to be [H]ard ! |
I do like the look of them for sure. Just got to figure out how many I need.
Act fast only 20 available it says & these are a hot item.
__________________ System #1 (in the works) Rampage II Extreme/ i920 - Stinger V8/ 6GB OCZ Tri Ch DDR3 PC-12800 Gold 8-8-8-24 1T - Corsair Dominator/ TRI SLI XFX 8800GTX 768MB - EK FC-8800GTX blocks/ Cooler Master 1250/ 150GB Raptor/ Supreme FX-II/ Pinnacle 24 System #2 P5QE-Deluxe/ E3110 45NM Xeon/ 4GB DDR3 PC-12800 OCZ Reaper/ SLI 7900GT's/ CoolerMaster 1250W/ Barracuda 500Gb 32mb/ X-Fi Extreme Gamer/ OCZ Laser mouse/ Zalman Theater 6M headphones/ 20.1" LG/ custom H2O in an H2gO My Heatware R3 |
Done ordered 3 packs of them. (2 in a pack)
Good move!, I wished Id bought a pair for my EK blocks.
__________________ E6750 + Apogee GT block DFI X38 LT 2x4870 74gb Raptor for OS, games Thermalrock Dragon Case (sprayed black) Loop 1: MCR 220 int. + cpu Loop 2: MCR 320, Swiftech Res. + 2x EK FC blocks) Pumps: 2x MCP655. |
I bought a pair of these for my EVGA HC16 waterblock and they didn't clear the backplate so I couldn't use them...
__________________ Gaming Rig: evga 680i rev. A1 // Q6600 @ 3.51 // evga 260GTX 216SC// 2X2GB GSkill DDR2 1000// Antec TP Quattro 850w // CM Stacker 830 Water Cooling: D-Tech Custom Fuzion // Danger Den 680i chipset block // evga HC16 GPU block// HW Labs Black Ice GTX Xtreme 360 // Swiftech mcp655 pump HTPC: Asus Commando // e6400 @ 3.4 // Crucial Ballistix PC2 8000 // evga 260GTX 216SC// LG super opti-blue HD optical drive// DVB clone PCI satellite receiver//OCZ GXStream 700w // ACFP7 CPU cooler // Antec p180 |
| Thread Tools | |
| Display Modes | |
