Old October 10, 2008, 02:07 PM
Dadi_oh's Avatar
Level up: 62% Level up: 62% Level up: 62%
Level: 5 - 29 points to level up
Default The Journey of a Watercooled GTX 260
Having just gone through this I thought I would share a few pointers and pics for people considering WC on their GTX 2xx cards.
First thing to consider is full block vs. dedicated GPU block and discretes for memory/power. In my case I chose dedicated GPU block for a couple of reasons:
1) Re-use when I inevitably upgrade. I don't have to drain my loop and reinstall. Plus $$$ investment in new full cover.
2) Flex issues. Some full cover blocks have had issues with flexing the board and causing some bowing over the GPU contact area. Since the dedicated GPU is only attached at 4 points very close to the GPU itself I am thinking there is no chance of this happening.
So once I decided dedicated GPU cooler I needed to think about the discrete cooling of the memory and power devices. I have tons of those little Zalman blue memory heatsinks but attaching lot's of these with new thermal tape is not much fun and until the tape sets they are prone to falling off when handling the card. Also, I have heard of overheating VRM's on the GTX2xx cards with discretes so something beefier should be considered.
That's when I saw these D-Tek Uni-sinks. They cover everything at once and they bolt securely to the card so no heatsinks dropping off.
Next I made the unfortunate assumption looking at the picture of the uni-sink that the rectangular opening for the GPU would support other types of waterblock. Bad idea. I ordered a Swiftch MCW60-R because of it's excellent performance data and discovered that the way that the uni-sink is built will only accept a D-Tek Fuzion GPU block. Unfortunately NCIX has a zero tolerance, no return policy on watercooling equipment even if it is still sealed in it's package
The next part of the puzzle is how the heck do you get the original heatsink cover off this thing? In the attached photo you will see the 10 screws that hold the front and back halves of the shell together. On my XFX card they were underneath the label so I chose to cut out the label in small circles to expose the screws. Peeling off the whole label would have been quite messy. Also, this back cover gets re-used with the unisink so keeping it clean looking is a bonus. Once you remove the 10 screws there are a variety of clips around the perimeter of teh shells that hold them together. Using a wide, sharp instrument (I used a chisel) you can leverage the parts apart in the area of the clips and they just pop open. I did it without damaging any clips but some people have reported breaking them. YMMV. To remove the top half you need to use a bit of a twisting motion combined with pulling it apart to loosen the TIM (Thermal Interface Material). Once apart clean it all up with IPA (India Pale Ale)... well actually IsoPropyl Alcohol but beer sounds good too
Fastening the Uni-sink is dead easy. About 10 screws and you are done. The Fuzion 2 water block then just fastens via 4 spring loaded screws to the unisink (don't forget the MX2 or your favourite TIM.
Attach it to your loop and start benching...
With my OEM heatsink and fan at 60% and Extra Voltage at 1.06V I was OC to 756 core and 1512 shaders and was hitting about 62-64C in Furmark.
With the Fuzion2 I was able to boost the extra voltage to 1.12 and increase shaders to 1620 and core to 810. Hitting about 43C in Furmark
Overall a highly recommended solution for your GTX 2xx card.
Rig 1: Q6600 @ 3.52GHz Swiftech Apogee WC on ASUS P5K-E NB WC, 2GB OCZ 1100MHz, XFX GTX260 XXX @ 783/1566/2600 WC, Samsung 226CW 22"
Rig2: E8200 @ 3.6GHz Vendetta HS on ASUS P5K-SE, 2GB OCZ 900MHz, Palit 8800GT Sonic 1GB @ 740/1850/2100, Acer X203W 20"
Rig3: E8400 @ 3.6GHz Vendetta HS on ASUS P5K-SE, 2GB OCZ 900MHz, BFG 8800GT @ 700/1753/2000 VF900, Samsung 245BW 24"
Rig4: E1200 @ 2.8GHz stock HSF on ECS 7050, 2GB OCZ Gold 800MHz. 7900GT. Compaq 17" LCD. My LINUX playhouse.
Old October 14, 2008, 06:09 PM
Default Reply
What happened to the uni-sink? It looks completely different to the old one...
Old October 14, 2008, 06:12 PM
Xilikon's Avatar
Level up: 61% Level up: 61% Level up: 61%
Level: 9 - 92 points to level up
It's a new revision it seems. Mine is the old version and I like it better than those foot massage soles
Xilikon - Team 33 and top 100 worldwide in Folding @ Home
Proud to be [H]ard !
Old October 14, 2008, 06:57 PM
MpG's Avatar
MpG MpG is offline
Level up: 44% Level up: 44% Level up: 44%
Level: 15 - 365 points to level up
The old version looks better, but the new one is better designed for airflow going down the length of the card from a front fan. Although either are technically overkill for the job, simply because of their size.
QX9650 @ 4.038GHz (425x9.5) | Asus Formula Maximus | GTX280 (777/1620/1404) | Mushkin XP2-8000 Redline 2x2GB
Q6600 @ 3.6GHz (400x9) | MSI P35 Platinum | 8800GTS 640MB (700/900) | Mushkin EM2-6400 2x2GB
Old October 21, 2008, 07:34 AM
matsta31's Avatar
Level up: 49% Level up: 49% Level up: 49%
Level: 12 - 209 points to level up
Quick question,
what do you have on your loop ?
Is the block restrictive ? I would consider putting it in my loop with the CPU, but was wondering If I would lose to much cooling power.
My loop is :
MCP 355 with Petra custom top - D-tek fuxzion v2 - PA 120.3 with 6 push-pull Loons.
It could become :
MCP 355 with Petra custom top - D-tek fuxzion v2 - D-Tek GPU bloc V2 - PA 120.3 with 6 push-pull Loons.
I have used Matin's flow rate estimator and it gives me 1.42 GPM with the D-Tek V1 tough. 1,42 brings me on the limit of Good to Great according to him. So Flow rate should be ok. Now heat dissipation capacity ?
And D-tek GPU V1 vs Dtek Gpu v2, is there any significant restrictions modifications ?
QX9650 @ 4.1 - Fuzion V2 - PA 120.3
DFI - LANPARTY DK P45-T2RS +
2 X 2 Gb Redline
Seagate 320G
BFG GTX280
Q6600 - Asus Maximus - 2 x 1 Gb OCZ Reaper - seagate 1Tb
Old October 21, 2008, 08:02 AM
Xilikon's Avatar
No problem with restriction. I have a MCP355 with Petra's top, Fuzion CPU v2 and Fuzion GPU v2 in the same loop and the temps is great. Anything over 1 GPM is good ;)
About the v1 vs v2, the v1 is very very restrictive but the v2 loosened it greatly to match a MCW60.
Old October 21, 2008, 08:28 AM
matsta31's Avatar
Good news.
XFX does cover a change of heatsink in warrenty, so I guess they wont refuse any RMA if I had to cut the scticker out....
2 X 2 Gb Redline
Seagate 320G
BFG GTX280
Old October 21, 2008, 09:07 AM
Level up: 77% Level up: 77% Level up: 77%
Level: 16 - 171 points to level up
Most Nvidia card manufacturers are quite linient, really you change a heatsink, as long as you put the original back before RMA, 99% it will be approved. I'm still thinking of selling me 4870 and going for a GTX260 Core 216 really.. Especially with the first attempt on installing a 4870 card, made the card not work, I am already freightened to do a second attempt..
Crucial Ballistix PC2-8500 4GB, Saphire HD4870 512mb
Lian Li V1000, Enermax Galaxy DXX 1000W
WC Loop: Swiftech Apogee GT, Danger Den D5 Pump EK FC-4870 Nickel Block,
Swiftech Micro Reservoir
Black Ice GT Stealth 240 Rad w/Zalman ZM-F3
Old October 24, 2008, 01:41 PM
Level up: 30% Level up: 30% Level up: 30%
Level: 10 - 197 points to level up
just a quick note to the OP, the uni-sink will work with the mcw60-r. I know because thats what i did, It takes a little moding though lol.
ABIT IP35 Pro
e8400 @ 4.05Ghz
EVGA GTX260@ 660/1250
4x1gig G.Skill 1066 @ 1080 5-5-5-15
Windows Vista Home Premium X64
Watercooled
CPU: D-Tek fuzion V1
GPU: Swiftech MCW60-R W/ Moddified Uni-Sink
Pump: Swiftech MCP655-B
Rad: Swiftech MCR320
Res: Swiftech Microres
Old October 24, 2008, 02:18 PM
Dashock's Avatar
Level up: 84% Level up: 84% Level up: 84%
Level: 16 - 120 points to level up
That my friend is a thing of beauty, if i was still in my glory days of gaming id buy this card but i shall wait as my 8800gt is still running solid. And Miggs78 you should have gone Nvidia buddy, oh well theres always next time cheers!!
Intel Xeon E3110 @ 3.0ghz
XFX 8800 GT Alpha Dog Edition
Asus P5Q-E
Mushkin Ascent Redline 8000 4gb DDR2 @ 1066 5-5-5-15 2.05v
OCZ 600W GameXstream
Seagate 7200.11 500gb
Seagate 7200.10 320gb
Antec Spot Cool
Logitech X-230
Samsung 32" 720P HDTV
Coolermaster Cosmos S/
