  #21 (permalink)
Old October 29, 2008, 05:45 AM
matsta31's Avatar
Reasonable you say ? Lol, on the stock cooler I do about 65-70 C while palying FC2. And when the fan kicks in, It is louder then the 5 yates loons and 2 Zalman. Mind you, they are all under volted, but it is still 7 fans....
Sold hardware again.....
Currently using WHS hardware....
  #22 (permalink)
Old October 29, 2008, 12:34 PM
Dadi_oh's Avatar
Originally Posted by ragenrok View Post
just a quick note to the OP, the uni-sink will work with the mcw60-r. I know because thats what i did, It takes a little moding though lol.
Yup I found a link with detailed instructions on where to cut away on the heatsink to allow space for the MCW60-R but to be honest I really wasn't anxious to do that level of modding to make it work. I just decided to take my losses on the resale of the MCW60-R. Which reminds me... time to bump the forsale thread
Rig1: Q9550 @3.8GHz Vendetta 2, P5Q-PRO, 6GB OCZ Reaper PC2-8500. 5870 1GB, GT240 Physx, Ultra LSP 750W, 2TB internal + 2TB external, 3X23" 5760X1080 eyefinity + GT240 Physx, HAF22 case 3X200mm : Win7 Pro
Rig2: E8200 @3.6GHz Vendetta HSF, DFI P45 LP-JR, 4GB 900MHz, 4870 512MB, X203W 20", Ultra Gladiator Case
Rig3: Q6600@ 3.5GHz H50, P5Q-PRO, 8GB, 8800GTS512, OCZ GameXStream 850W, Samsung 245BW 24" + 19" dual: Snow Leopard + Parallels Win7
Rig4: MAC mini Snow Leopard
Laptop: Macbook Pro 15"
  #23 (permalink)
Old October 30, 2008, 03:59 PM
ragenrok's Avatar
hehe its not much work, you can do it with a mini zipdisk (I used a 1.5" disk) and a drill bit and only takes about 10 min but I can't blame you, I considered doing the same thing till I realized I had all the tools I needed to mod my uni-sink at work and a wife that would of shot me if I had spent more money on my computer at the time lol.
