My overzealous water cooling plan of water cooling the CPU (E5200) and video cards got slashed in half due to a revamped budget. So it looks like I'm going to just be putting the CPU under water. So here is the parts list I have come up with. Swiftech Apogee GTZ LGA775 CPU Water Block Swiftech MCR220 Quiet Power Dual 120mm Radiator 2x Scythe Slip Steam Kaze Jyuni 120mm Fans Swiftech MCP665-B 12v Pump Swiftech MCRES-Micro Clear Hi-Flow Reservoir Feser One Feser Tube UV Orange 3/8" ID 1/2" OD 3pkgs of Danger Den G1/4 to 3/8IN High Flow Barbs Total - $267.90 My only question is can the 1/2 barbs on the MCP665-B be replaced?
__________________ "Though I walk through the shadow of the Valley of Death I shall fear no evil as my M4A1 Carbine is locked and loaded." - Rigless [Heatware] BALISTX.com |
| Quote:
Have a look at this pump.... NCIX.com - Buy Danger Den DDCPX-PRO 12V Water Cooling Pump with Mounting Hardware 1/2IN Chrome Barb Fittings - DD-CPX-PRO In Canada. Ships with both 1/2 & 3/8 chrome barbs, and the flow rates are absolutely amazing!!!!
__________________ Gigabyte P35-DQ6 / E8400 / 2X2 Gig Mushkin PC2 8500 Ascents / Corsair TX750W PSU / Gigabyte 8800GTS / CoolerMaster Cosmos S / MCP655 WC Pump / MCR320 Rad / 6X Yate Loons / PA120.1 / 2X Scythe Ultra Kaze / Swiftech Apogee GTZ WB / Samsung 2253BW ASUS P5Q Pro / Q6600 / 2X1 Gig Supertalent PC2 6400 / PC P&C 750W Silencer / HIS 3870 IceQ3 / HT Omega Striker 7.1 / MCR220-QP-Res / DD DDCPX-Pro / Apogee GT / Swiftech MCW30 / Highspeed PC Tech Station / Samsung 931BF |
I'd say Yates (from Petra), S-FLEX or ZM-F3s for the radiator instead. Slipstream don't really have great pressure for rad usage. Otherwise it looks good, other than the pump which was already said.
__________________ Xeon Quad X3350 | 3.40GHz (Damn X38 chipset) ASUS Maximus Formula | BIOS RF0410 2GB Corsair Dominator | 850MHz [/font]4-4-4-12-2T 2GB OCZ Platinum Rev2 | 850MHz 4-4-4-12-2T HIS ICEQ4 Turbo HD4850 @ 700/1200 X-Fi XtremeMusic Antec TruePower Quattro 850W Antec 900 [ HEATWARE ] |
Steve: thanks that pump is cheaper than the MCP665-B phil3_66666: The 3/8" tub flows faster and easier to get tight bends without kinking.
For the fans I was going buy the CFMs How bout these fans? Scythe Ultra Kaze 120MM High Static Pressure Fan 38MM 3000RPM 133.6CFM 45.9DBA
| Velcro eh? Sounds like a good idea. I may pick some up at my local Wally World.
If you really want to have a complete wc setup, I just may be able to help you. Figure out how much that EK 9600 block will cost you, then send me a PM. I have a few parts in which you may be interested.
__________________ Main: GA-X58-Extreme - i7 920 - TX750W - Raptor - 3Gb DDR3-1333 Triple-Channel - GTX260 SLI'ed - TRUE - P182 HTPC: M3A78-EM - 5000+ X2 - HX520W - 'cuda 1Tb - XP2-5300 2x512Mb - 9800GT - SI-128 - Prelude - Moneual 932B |
| Thanks Charlie will do.
| Thread Tools | |
| Display Modes | |
