Old October 8, 2008, 05:20 PM
FrankyG's Avatar
Level up: 28% Level up: 28% Level up: 28%
Level: 9 - 170 points to level up
Default System installed !
Installed my water cooling stuff this evening did not run it since I don't have any distilled water. Heres a couple pics please let me know if I did any thing wrong. The loop goes a follows.
Intel Q9550 @ 4.02GHZ
Evga 790i Ultra SLI
4GB Corsair XMS3 1600Mhz
2x Evga GTX280 SSC 1GB
Seagate 1TB HD
Antec 1000W PSU
Chieftec Dragon Case
Custom Watercooling Kit
Old October 8, 2008, 05:28 PM
Level up: 77% Level up: 77% Level up: 77%
Level: 16 - 171 points to level up
You had a lot of space inside the case for the pump really.. Which would also avoid the tube crossing you have near the cpu.
But nonetheless, looks kool!!
Crucial Ballistix PC2-8500 4GB, Saphire HD4870 512mb
Lian Li V1000, Enermax Galaxy DXX 1000W
WC Loop: Swiftech Apogee GT, Danger Den D5 Pump EK FC-4870 Nickel Block,
Swiftech Micro Reservoir
Black Ice GT Stealth 240 Rad w/Zalman ZM-F3
Old October 8, 2008, 05:36 PM
magictorch's Avatar
Level up: 96% Level up: 96% Level up: 96%
Level: 17 - 34 points to level up
Looks like the loop is set up just fine in terms of overall configuration. As Miggs said it would look a bit cleaner if you brought the pump into the case but its well thought out all the same.
I quite like the way you've mounted the rad.
E6750 + Apogee GT block
DFI X38 LT
2x4870
74gb Raptor for OS, games
Thermalrock Dragon Case (sprayed black)
Loop 1: MCR 220 int. + cpu
Loop 2: MCR 320, Swiftech Res. +
2x EK FC blocks)
Pumps: 2x MCP655.
Old October 8, 2008, 05:44 PM
MpG's Avatar
MpG MpG is offline
Level up: 44% Level up: 44% Level up: 44%
Level: 15 - 365 points to level up
Yeah, I like that rad mounting too. Technically, you're getting slightly cooler air this way, rather than grabbing what's leaving the case, and it'll be a cinch to vacuum dust out if it becomes a problem. And if you ever feel like a little more cooling power, just bolt a couple of fans on the front of the rad for a push-pull setup.
Watch the opening that your tubes are going through - some of those edges look a little sharp - wouldn't want them to rub through your tubing over time. You might have problems with the pump trying to make the case vibrate. If so, some sort of soft-mounting might be necessary, but hopefully not.
QX9650 @ 4.038GHz (425x9.5) | Asus Formula Maximus | GTX280 (777/1620/1404) | Mushkin XP2-8000 Redline 2x2GB
Q6600 @ 3.6GHz (400x9) | MSI P35 Platinum | 8800GTS 640MB (700/900) | Mushkin EM2-6400 2x2GB
Old October 8, 2008, 05:54 PM
Yeah I would also personally use an external rad, I like the idea of cool fresh air hitting the rad first, slightly better temps, and the dust issue..
I forgot to mention, you might want to put something on edges of the hole you cut in the fan position to pass tubing, sharp edges, even put some electronic tape..
Old October 8, 2008, 05:58 PM
Phobia's Avatar
Level: 10 - 158 points to level up
I, like everyone else, think thats an awsome way to mount your rad. Would never have thought of it, but its a sweet way of doing it. There is room for the pump inside, but to each his own, and its not too bad.. looks like its bolted on damn good
Mountain Mods u2 UFO
Intel qx9650 @ 4.2 ghz
4x1 gb corsair dominator 1066mhz
Asus p5e
Evga 9800GX2
Xp pro on 2 seagate 320 gb, raid 0
Vista Ultimate on 2 seagate 250 gb, raid 0
Corsair 1000HX
WC loop: mcp665, pa 120.2, dtek fuzion, DD 8800 gts full coverage, swiftech mcres-micro
Old October 8, 2008, 06:23 PM
Now you made me jealous... I'm coming to steal that case of you.. oh hold on.. maybe I'll steal Phobe's MM :P ^^
Old October 8, 2008, 06:35 PM
Cptn Vortex's Avatar
Level up: 31% Level up: 31% Level up: 31%
Level: 21 - 834 points to level up
Neat idea, but looks like bleeding/getting the air bubbles out is not going to be an easy task.
The Vortex H20
Case....not sure what to call it
DFI X38 LT
Xeon X3210 @ 3.2GHZ 1.30V
PNY 9800GX2 (750/2200)
4GB Corsair Dominator 2x2gb kit DDR2 1066 5-5-5-15 2.0V
Ultra X3 1000W PSU
HT Omega Striker
2x500GB Hitachi RAID 0, 250 Seagate
Sharp 32" Aquos 1080p
Benq W500 1080i Pojector.
Watercooling:
Loop 1 - D-Tek Fuzion Quad Nozzle Bowed, MCR320+Zalman ZM-F3 Fans, MCP655, MCRES Micro.
Loop 2 - DB-1, DD 9800GX2 block, MCW30, MCR320, tLine res.
Old October 8, 2008, 07:26 PM
matsta31's Avatar
Level up: 49% Level up: 49% Level up: 49%
Level: 12 - 209 points to level up
Bah try bleeding an MM case , and this will be nothing compared to it :)
Huh, I never had a mcp 655 but where is the inlet and the outlet ?
I tough the outlet was the top of the pump ? If so, filling it will be a bit of a PITA.
It is easier, anyway for me, to have the T at the inlet of the pump when innitially filling it. The way I think your pump works, it wont have water to push it up when you fill it.
Owner of mcp655, tell me what you think ?
QX9650 @ 4.1 - Fuzion V2 - PA 120.3
DFI - LANPARTY DK P45-T2RS +
2 X 2 Gb Redline
Seagate 320G
BFG GTX280
Q6600 - Asus Maximus - 2 x 1 Gb OCZ Reaper - seagate 1Tb
Old October 8, 2008, 07:47 PM
MpG's Avatar
MpG MpG is offline
No worries, he's got the T-line on the pump's inlet.
