Old October 8, 2008, 07:55 PM
BALISTX's Avatar
Level up: 32% Level up: 32% Level up: 32%
Level: 21 - 826 points to level up
nice setup. Personally I would have also put the pump and that res inside the case.
"Though I walk through the shadow of the Valley of Death I shall fear no evil as my M4A1 Carbine is locked and loaded."
- Rigless
[Heatware]
BALISTX.com
Old October 9, 2008, 04:22 AM
FrankyG's Avatar
Level up: 28% Level up: 28% Level up: 28%
Level: 9 - 170 points to level up
Thanks for the comments, I fixed the few issues pointed out I will bleed the system tonight and get it up and running I will have more pictures shortly.
Intel Q9550 @ 4.02GHZ
Evga 790i Ultra SLI
4GB Corsair XMS3 1600Mhz
2x Evga GTX280 SSC 1GB
Seagate 1TB HD
Antec 1000W PSU
Chieftec Dragon Case
Custom Watercooling Kit
Old October 9, 2008, 06:15 AM
Level up: 77% Level up: 77% Level up: 77%
Level: 16 - 171 points to level up
Great.. Good luck
Crucial Ballistix PC2-8500 4GB, Saphire HD4870 512mb
Lian Li V1000, Enermax Galaxy DXX 1000W
WC Loop: Swiftech Apogee GT, Danger Den D5 Pump EK FC-4870 Nickel Block,
Swiftech Micro Reservoir
Black Ice GT Stealth 240 Rad w/Zalman ZM-F3
Old October 10, 2008, 04:05 AM
FrankyG's Avatar
Well got the system bleed. took about 1 hours lol ! But it was worth it ! My OC'd Q9550 @ 3.82Ghz runs at 40 idle and tops out at 51 I think that is pretty good before it would idle at those temps and top out at around 62
Evga 790i Ultra SLI
Seagate 1TB HD
Antec 1000W PSU
Old October 10, 2008, 04:33 AM
Level up: 48% Level up: 48% Level up: 48%
Level: 5 - 40 points to level up
Originally Posted by MpG
Watch the opening that your tubes are going through - some of those edges look a little sharp - wouldn't want them to rub through your tubing over time. You might have problems with the pump trying to make the case vibrate. If so, some sort of soft-mounting might be necessary, but hopefully not.
correct on sharp edges use some split loom from canadiantire in auto/electric section or slit any left over tubing an slip it on the edge of steel
for pump vibration can susspend off your L brackets with elastics
