Old October 10, 2008, 09:16 AM
Level up: 77% Level up: 77% Level up: 77%
Level: 16 - 171 points to level up
But really Magic, I still think you should be fine with 1 MCP pump to handle 2 radiators really.. It's a pretty powerful pump..
I guess we just need MpG to clarify this... *sits in anticipation*
Crucial Ballistix PC2-8500 4GB, Saphire HD4870 512mb
Lian Li V1000, Enermax Galaxy DXX 1000W
WC Loop: Swiftech Apogee GT, Danger Den D5 Pump EK FC-4870 Nickel Block,
Swiftech Micro Reservoir
Black Ice GT Stealth 240 Rad w/Zalman ZM-F3
Old October 10, 2008, 11:33 AM
Xilikon's Avatar
Level up: 61% Level up: 61% Level up: 61%
Level: 9 - 92 points to level up
Originally Posted by magictorch View Post
Balistx Id recommend the copper enzotech ramsinks as they come with a good sticky thermal pad and are of high quality.
As for the EK blocks, Blackice has assured me hes shipped the pump I bought at his FS thread so I should have the extra MCP655 pumps by next week- =one for the GPU loop and one for the cpu loop.
I think an MCP655 will be fine for 1 rad, an EK GPU block and a cpu for anyone looking at that.
Yes, 1 pump for 2 big blocks (CPU/GPU) is the most we can go. When we get to 3 or more, it's better to split the loops but you can afford to have a smaller rad for the GPU since they aren't temp bound but voltage bound. The CPU need the coldest water temp.
The main question is to know if you have room for 2 loops since it take a lot of room with 2 pumps and 2 radiators.
Xilikon - Team 33 and top 100 worldwide in Folding @ Home
Proud to be [H]ard !
Old October 10, 2008, 12:13 PM
magictorch's Avatar
Level up: 96% Level up: 96% Level up: 96%
Level: 17 - 34 points to level up
Xilikon your right it takes a lot of room.
Both my rads will be mounted externally, the case has a fair bit of room inside for the res and two pumps. In the future though its either techstation, TJ07, blackpearl, or a mountainmods case to hold all this. Currently its going to look like the Ateam have been working on it after an all night party.
E6750 + Apogee GT block
DFI X38 LT
2x4870
74gb Raptor for OS, games
Thermalrock Dragon Case (sprayed black)
Loop 1: MCR 220 int. + cpu
Loop 2: MCR 320, Swiftech Res. +
2x EK FC blocks)
Pumps: 2x MCP655.
Old October 10, 2008, 02:59 PM
MpG's Avatar
MpG MpG is offline
Level up: 44% Level up: 44% Level up: 44%
Level: 15 - 365 points to level up
I need to read up on this though as MPG and Xilicon werent impressed with the idea of multi blocks and rads with a res with one MCP655--
It's not the rads, it's those GPU blocks specifically.
I'm running both my CPU and GPU in the same loop with a pair of rads, and only using a little DDC 3.1 pump, but I'm still getting over 1.5gpm. But that's because I deliberately used blocks with low restriction. If I'd used one of those EK GPU block instead, things wouldn't be nearly as comfortable. If I had a second card with one of those blocks on it... ouch.
If you only want the blocks for their looks, then I wouldn't worry about it. But if you're serious about temperatures, your CPU cooling is probably going to suffer a little from the reduced flow.
QX9650 @ 4.038GHz (425x9.5) | Asus Formula Maximus | GTX280 (777/1620/1404) | Mushkin XP2-8000 Redline 2x2GB
Q6600 @ 3.6GHz (400x9) | MSI P35 Platinum | 8800GTS 640MB (700/900) | Mushkin EM2-6400 2x2GB
Old October 10, 2008, 03:23 PM
magictorch's Avatar
MPG thanks for the advice, I'm going to use two MCP655's. Its good to know about the rads though, not so much the EK blocks you mentioned earlier.
Looks are nice but I want to learn how to push the system more. I'd originally posted here as I wasn't sure the extra MCP655 I'd ordered in a FS thread was going to be delivered... needed to know if 1 MCP655 could do the job.
DFI X38 LT
2x4870
2x EK FC blocks)
Pumps: 2x MCP655.
Old October 10, 2008, 05:05 PM
Level up: 87% Level up: 87% Level up: 87%
Level: 14 - 79 points to level up
1 is more than enough, look at the loop I'm pushing with one.
Passive watercooling...
Flow is great. The pump is rated to 50 psi. My loop is giving about 6-8 in back pressure.
Old October 11, 2008, 09:47 AM
magictorch's Avatar
Squeetard, I love what youve done there.
Techstation is definitely where I'd like to go, although my dog does shed a bit. After what MPG and Xilikon have said it wouldnt surprise me if 2 EK blocks would slow the flow even more than the condenser you have included though.
I have 1 MCP655 vario version already and am using 1/2inch tubing. I also have all the parts now minus the extra pump. The EK blocks were quite pricey though, although I got a good deal on one of them. Really keen to build but had issues getting that 2nd pump.
Originally Posted by KaptCrunch View Post
get the vario version of D5
yes but need to use a res in loop to feed that pump
D5: 3.1m head with 1200lph
D5 vario: 3.5m head with 1200lph
what size of tubing will be using?
DFI X38 LT
2x4870
2x EK FC blocks)
Pumps: 2x MCP655.
