But really Magic, I still think you should be fine with 1 MCP pump to handle 2 radiators really.. It's a pretty powerful pump.. I guess we just need MpG to clarify this... *sits in anticipation*
__________________ Intel E8400, Biostar TPower i45 Crucial Ballistix PC2-8500 4GB, Saphire HD4870 512mb Lian Li V1000, Enermax Galaxy DXX 1000W Samsung 931BW 19" LCD, Logitech MX Revolution WC Loop: Swiftech Apogee GT, Danger Den D5 Pump EK FC-4870 Nickel Block, Swiftech Micro Reservoir Black Ice GT Stealth 240 Rad w/Zalman ZM-F3 |
Xilikon your right it takes a lot of room. Both my rads will be mounted externally, the case has a fair bit of room inside for the res and two pumps. In the future though its either techstation, TJ07, blackpearl, or a mountainmods case to hold all this. Currently its going to look like the Ateam have been working on it after an all night party.
__________________ E6750 + Apogee GT block DFI X38 LT 2x4870 74gb Raptor for OS, games Thermalrock Dragon Case (sprayed black) Loop 1: MCR 220 int. + cpu Loop 2: MCR 320, Swiftech Res. + 2x EK FC blocks) Pumps: 2x MCP655. Last edited by magictorch; October 10, 2008 at 12:37 PM. |
| Quote:
I'm running both my CPU and GPU in the same loop with a pair of rads, and only using a little DDC 3.1 pump, but I'm still getting over 1.5gpm. But that's because I deliberately used blocks with low restriction. If I'd used one of those EK GPU block instead, things wouldn't be nearly as comfortable. If I had a second card with one of those blocks on it... ouch. If you only want the blocks for their looks, then I wouldn't worry about it. But if you're serious about temperatures, your CPU cooling is probably going to suffer a little from the reduced flow.
__________________ QX9650 @ 4.038GHz (425x9.5) | Asus Formula Maximus | GTX280 (777/1620/1404) | Mushkin XP2-8000 Redline 2x2GB Q6600 @ 3.6GHz (400x9) | MSI P35 Platinum | 8800GTS 640MB (700/900) | Mushkin EM2-6400 2x2GB |
MPG thanks for the advice, I'm going to use two MCP655's. Its good to know about the rads though, not so much the EK blocks you mentioned earlier. Looks are nice but I want to learn how to push the system more. I'd originally posted here as I wasn't sure the extra MCP655 I'd ordered in a FS thread was going to be delivered... needed to know if 1 MCP655 could do the job.
__________________ E6750 + Apogee GT block DFI X38 LT 2x4870 74gb Raptor for OS, games Thermalrock Dragon Case (sprayed black) Loop 1: MCR 220 int. + cpu Loop 2: MCR 320, Swiftech Res. + 2x EK FC blocks) Pumps: 2x MCP655. Last edited by magictorch; October 10, 2008 at 03:30 PM. |
1 is more than enough, look at the loop I'm pushing with one. Passive watercooling... Flow is great. The pump is rated to 50 psi. My loop is giving about 6-8 in back pressure. |
Squeetard, I love what youve done there. Techstation is definitely where I'd like to go, although my dog does shed a bit. After what MPG and Xilikon have said it wouldnt surprise me if 2 EK blocks would slow the flow even more than the condenser you have included though. I have 1 MCP655 vario version already and am using 1/2inch tubing. I also have all the parts now minus the extra pump. The EK blocks were quite pricey though, although I got a good deal on one of them. Really keen to build but had issues getting that 2nd pump .
__________________ E6750 + Apogee GT block DFI X38 LT 2x4870 74gb Raptor for OS, games Thermalrock Dragon Case (sprayed black) Loop 1: MCR 220 int. + cpu Loop 2: MCR 320, Swiftech Res. + 2x EK FC blocks) Pumps: 2x MCP655. |
| Thread Tools | |
| Display Modes | |
