It's not absolutely necessary, in fact most folks seem to do fine without it. That said.... it will improve airflow a bit in that it will help get rid of the "dead spot" in the middle of the fan.
__________________ Gigabyte P35-DQ6 / E8400 / 2X2 Gig Mushkin PC2 8500 Ascents / Corsair TX750W PSU / Gigabyte 8800GTS / CoolerMaster Cosmos S / MCP655 WC Pump / MCR320 Rad / 6X Yate Loons / PA120.1 / 2X Scythe Ultra Kaze / Swiftech Apogee GTZ WB / Samsung 2253BW ASUS P5Q Pro / Q6600 / 2X1 Gig Supertalent PC2 6400 / PC P&C 750W Silencer / HIS 3870 IceQ3 / HT Omega Striker 7.1 / MCR220-QP-Res / DD DDCPX-Pro / Apogee GT / Swiftech MCW30 / Highspeed PC Tech Station / Samsung 931BF |
A nice easy mod to make your own shroud :Get some cheap or old 120mm fans. Cut the Fan part out of it. There you have it, the perfect shroud.
__________________ The Vortex H20 Case....not sure what to call it DFI X38 LT Xeon X3210 @ 3.2GHZ 1.30V PNY 9800GX2 (750/2200) 4GB Corsair Dominator 2x2gb kit DDR2 1066 5-5-5-15 2.0V Ultra X3 1000W PSU HT Omega Striker 2x500GB Hitachi RAID 0, 250 Seagate Sharp 32" Aquos 1080p Benq W500 1080i Pojector. Watercooling: Loop 1 - D-Tek Fuzion Quad Nozzle Bowed, MCR320+Zalman ZM-F3 Fans, MCP655, MCRES Micro. Loop 2 - DB-1, DD 9800GX2 block, MCW30, MCR320, tLine res. |
In my experience, the shroud is not worth the cost. I have done with and without and none of my most recent loop use one. Also, I see you use a vendetta-2 on a dual core, wich is a really good set up already. Are you going water for a bigger overclock ? If so, what are you current temp, and what is limiting your overclock ?
__________________ QX9650 @ 4.1 - Fuzion V2 - PA 120.3 DFI - LANPARTY DK P45-T2RS + 2 X 2 Gb Redline Seagate 320G BFG GTX280Q6600 - Asus Maximus - 2 x 1 Gb OCZ Reaper - seagate 1Tb |
I just wanted to try water cooling for the sake of water cooling. I haven't started overclocking, I just assembled the rig and got it going. Going to try overclocking it this weekend.
__________________ Intel E8400 OCZ Vendetta 2 Asus P5Q Pro G.Skill F2-8500CL5D-4GBPK Diamond 4870 1GB 2 Seagate Barracuda 7200.11 640GB Corsair TX750 AuzenTech X-FI Prelude Coolermaster HAF 932 |
Speaking of Shrouds.....
Now that things got some junk in her trunk wow thats massive. Are those the Zalmans??
__________________ Intel Xeon E3110 @ 3.0ghz XFX 8800 GT Alpha Dog Edition Asus P5Q-E Mushkin Ascent Redline 8000 4gb DDR2 @ 1066 5-5-5-15 2.05v OCZ 600W GameXstream Seagate 7200.11 500gb Seagate 7200.10 320gb Antec Spot Cool Logitech X-230 Samsung 32" 720P HDTV Coolermaster Cosmos S/ Swiftech Mcp655/ MCR-320-QP/ 6X Noctua NF-P12'S/ Swiftech Apogee GT/ Swiftech Mcw-60/ Swiftech Micro-Res. |
I just gutted 2 old 120mm fans.
__________________ CSE: Lian-Li PC-A70 MOB: Biostar T-Power I45 CPU: Intel C2D E8600 @ 4.3ghz RAM: 4gb g.skill pc2-8000 GPU: XFX 8800 GT Alpha Dog Edition PSU: PC Power & Cooling 750w Heatware: My Heatware |
Did you put some kind of metal piece on the sides, where did you screw them?
__________________ Intel E8400, Biostar TPower i45 Crucial Ballistix PC2-8500 4GB, Saphire HD4870 512mb Lian Li V1000, Enermax Galaxy DXX 1000W Samsung 931BW 19" LCD, Logitech MX Revolution WC Loop: Swiftech Apogee GT, Danger Den D5 Pump EK FC-4870 Nickel Block, Swiftech Micro Reservoir Black Ice GT Stealth 240 Rad w/Zalman ZM-F3 |
Those are the Thermochill Shrouds, with Scythe Ultra Kaze 3000RPM's. Got this sucker from Black_Ice-Dragon.
| Thread Tools | |
| Display Modes | |
