Old October 2, 2008, 10:33 PM
biff's Avatar
Default Not happy with NF-P12's
I recently switched the fans on my rads over to Noctua NF-P12's and I'm not happy at all with them. They have a whine to them like what a car horn several blocks away would sound like. I used the speed reducers to slow them down, currently using a black one (whichever that one is) to feed two fans with a 'Y' splitter. They sound not too bad now but as soon as I put me case sides on there is vibration. My crappy CM case fans don't do that and TBH sound better. The CM's may not be more quiet as a dBm meter would read but the sound signature is much more bearable. I'm not sure what the performance difference is between the two, I'm just starting temp testing now so the Noctua may 'work' better but they're not going to stay given the noise issues.
So that said what other options do I have?
Q6600 @ 3.83GHz w/ D-Tek Fusion
Asus P5Q-PRO
2x 2GB PC8000 Mushkin Redlines @ 1020MHz w/5-5-5-12 timings
EVGA GTX 280 (SC?)
OCZ Gamer Xtreme 600W PSU
Cooler Master Cosmos on water
Old October 2, 2008, 10:46 PM
MpG's Avatar
MpG MpG is offline
Be interested to hear your results. My own Noctua's are behaving quite nicely on a radiator, and I'm pretty anal-retentive about noise, so I'm not sure what's wrong with yours.
In this case, I'd probably point you towards the Scythe S-Flex fans. The E-series would match closest in rpms, while the F-series would be a little faster (and louder). Great bearings, long-life, and solid radiator performance. Easy to order online, of course, but if you find yourself heading into the GTA, I've noticed that Canada Computers stores have started stocking them as well.
Cptn Vortex's Avatar
Buy Zalman ZM-F3 120MM Sleeve Bearing Case Fan Black 900/1800RPM 20/34DBA 3PIN Connector Awesome fans. Amazing performance, speed reducers, rubber mounts, all in 1 package for under $6. I use 6 of them, running about 1200RPM and they push alot of air, with little to no motor noise.
The Vortex H20
MSI Z77A-GD65
Intel i7 3770K @ 4.6GHZ 1.28v
Galaxy GTX 680 @ 1241MHZ
8GB Mushkin Blackline 1600MHZ 9-9-9-24 1.5v
Asus Xonar Essence STX
OCZ Z-Series GOLD 850W
2 x 128GB Corsair Force GT SATA3 SSD RAID0 :)
Acheiva Shimian Q270 Lite 2560x1440
Benq W500 Pojector.
Watercooling:
EK Supreme HF, EK FC GTX 680 Block, MCR320+Gelid Silent 12 Push/Pull, DD Pump, EK Multioption 100ml Res, EK Coolstream XT 220 RAD Gelid Wings Push/Pull.
Old October 2, 2008, 11:37 PM
Dashock's Avatar
Yea im not having any issues with my 6 Noctua's either maybe its defective?
Intel Xeon E3110 @ 3.0ghz
XFX 8800 GT Alpha Dog Edition
Asus P5Q-E
Mushkin Ascent Redline 8000 4gb DDR2 @ 1066 5-5-5-15 2.05v
OCZ 600W GameXstream
Seagate 7200.11 500gb
Seagate 7200.10 320gb
Antec Spot Cool
Logitech X-230
Samsung 32" 720P HDTV
Coolermaster Cosmos S/
Old October 2, 2008, 11:50 PM
Just ordered 3 more Zalmans.... I am going to be the Zalman king!
The Vortex H20
MSI Z77A-GD65
Benq W500 Pojector.
Watercooling:
Old October 3, 2008, 04:29 AM
for the moment im the king i have 7 of it.. bur when you order coming you will be
Old October 3, 2008, 04:30 AM
Dashock's Avatar
lol @ Vortex whats the next project for the Great ole Captain Vortex.
Asus P5Q-E
Antec Spot Cool
Logitech X-230
Old October 3, 2008, 06:07 AM
cegras's Avatar
I also find that noctuas produce a whining, resonance noise, especially on 12v and if they are close to each other.
So much for vortex control notches ..
Old October 3, 2008, 06:45 AM
Sniper's Avatar
lol they aren't noisy or anything at 34DBA maxed I bet ha
Old October 3, 2008, 07:09 AM
Hah!! suckers.. Vortex and Gang suggestions.. :P.. I actually have them on full speed, no rpm reduction.. and are still quiet, I've used Panaflo's, and I know noise, these are not ...
