| Seriously, those Zalman's are very good (sleeve bearing, possible shortened life if run horizontally), but there is no way they qualify as "quiet" while running full speed. "Moderate", perhaps.
__________________ QX9650 @ 4.038GHz (425x9.5) | Asus Formula Maximus | GTX280 (777/1620/1404) | Mushkin XP2-8000 Redline 2x2GB Q6600 @ 3.6GHz (400x9) | MSI P35 Platinum | 8800GTS 640MB (700/900) | Mushkin EM2-6400 2x2GB |
Well I might not be as picky as you, but seriously it wasn't as loud as you think... Hek I could hear my pump more than anything..
__________________ Intel E8400, Biostar TPower i45 Crucial Ballistix PC2-8500 4GB, Saphire HD4870 512mb Lian Li V1000, Enermax Galaxy DXX 1000W Samsung 931BW 19" LCD, Logitech MX Revolution WC Loop: Swiftech Apogee GT, Danger Den D5 Pump EK FC-4870 Nickel Block, Swiftech Micro Reservoir Black Ice GT Stealth 240 Rad w/Zalman ZM-F3 |
Yeah they are not loud, but they are also not silent. I like my fans below 1200rpm. That is the sweet spot for me. When the computer goes back to the living room, I'll bump em back up to 1500rpm as it a larger room space, so the sound is drowned out.
__________________ The Vortex H20 Case....not sure what to call it DFI X38 LT Xeon X3210 @ 3.2GHZ 1.30V PNY 9800GX2 (750/2200) 4GB Corsair Dominator 2x2gb kit DDR2 1066 5-5-5-15 2.0V Ultra X3 1000W PSU HT Omega Striker 2x500GB Hitachi RAID 0, 250 Seagate Sharp 32" Aquos 1080p Benq W500 1080i Pojector. Watercooling: Loop 1 - D-Tek Fuzion Quad Nozzle Bowed, MCR320+Zalman ZM-F3 Fans, MCP655, MCRES Micro. Loop 2 - DB-1, DD 9800GX2 block, MCW30, MCR320, tLine res. |
My PC sits on my desk, right infron of me. 1800rpm is barable to me, considering my old rig has 2 x 120mm 120cfm panaflo fans in the same room I used to sleep, especially when I download torrents at night, pc has to stay on, but I can't loose sleep. ....
You've probably grown accustomed to the noise. If the room is quiet enough (e.g. fridge is off), I can hear the quiet whine coming from the power brick in my samsung monitor .. : ) As for good fans, I would recommend S-Flex, ZM-F3. Or Papst .. if you can them anywhere. |
Just thought I'd throw in an update here. I did a little nearly non-scientific comparison on different fan setups. I ran orthos - for many hours - and used coretemp to log the temps readings and then opened those in excel just to get the average temp for CPU. Going from a NF-P12 at full speed to a NF-P12+ULN adapter made a whole 0.7 degrees C difference. I couldn't care less about 0.7 degrees if it meant quieter operation. Next I replaced the Noctuas with the stock CM fans that came with my case. At full speed they sounded better than the noctuas at low speed, aybe not more quiet but the sound signature was much more bearable. I found they were the most quiet using the LN adapters borrowed from the noctuas. Using the ULN adapters made the fans spin too slowly and would now and would run with a ticking sound. AFAICT the temps are identical to the low speed noctuas but I'll have to do another orthos run to be a fair comparison. At the end of the day though it doesn't really matter since this combo keeps it 'cool enough' as I didn't have to back off my OC.
__________________ e3110 @ 4.14GHz w/ D-Tek Fusion Gigabyte GA-P35-DS3R rev.1 2x 2GB PC8000 Mushkin Redlines @ 920MHz w/5-5-5-12 timings Asus EN8800GT Top stock speed w/ DD Maze5 OCZ Gamer Xtreme 600W PSU Cooler Master Cosmos on water |
Hey biff contact Noctua and see what they have to say, not all fans carry a 6 year warranty best to take advantage of it. mailto:support@noctua.at
__________________ Intel Rig Biostar T-Power I45 / Intel E8400 EO 1.4v @ 4.25Ghz / Sunbeam Core Contact Freezer / Muskin Ascent Redline XP2-8000 2x2Gb / EVGA GTX280 1Gb *700/1506/1200* / Samsung Spinpoint F1 750Gb 32Mb x 2 / Razer Barracuda AC-1 Gaming Audio / Antec P182 / Antec TPQ 850 Watt AMD Rig (Future folding@home box) |
I'm not sure if I'm the only one to believe this, but after switching out my other fans and replacing them with NF-P12's, I was less then impressed with the temperature results. I really think the fans are over hyped. James |
I am not having any issues with my fans but if its only a 0.7 difference in temps Biff i think ill put all 6 of mine on the lowest rpm. we have 6 years warranty definetely use it. One Coolermaster fan was louder then 6 of my Noctua's i could clearly hear the whine when i replaced it with a thermaltake fan i had it was back to quiet.
__________________ Intel Xeon E3110 @ 3.0ghz XFX 8800 GT Alpha Dog Edition Asus P5Q-E Mushkin Ascent Redline 8000 4gb DDR2 @ 1066 5-5-5-15 2.05v OCZ 600W GameXstream Seagate 7200.11 500gb Seagate 7200.10 320gb Antec Spot Cool Logitech X-230 Samsung 32" 720P HDTV Coolermaster Cosmos S/ Swiftech Mcp655/ MCR-320-QP/ 6X Noctua NF-P12'S/ Swiftech Apogee GT/ Swiftech Mcw-60/ Swiftech Micro-Res. |
| Thread Tools | |
| Display Modes | |
