  #21 (permalink)
Old October 3, 2008, 10:55 AM
Level up: 80% Level up: 80% Level up: 80%
Level: 22 - 269 points to level up
Originally Posted by Sniper View Post
Curious as to why this is? As I do not know why lol.
$5 filler+$1 tube = no need for expensive xspc top lol
It is a nice looking product though no doubt.
Less tubing = better.
CSE: Lian-Li PC-A70
MOB: Biostar T-Power I45
CPU: Intel C2D E8600 @ 4.3ghz
RAM: 4gb g.skill pc2-8000
GPU: XFX 8800 GT Alpha Dog Edition
PSU: PC Power & Cooling 750w
Heatware: My Heatware
  #22 (permalink)
Old October 3, 2008, 11:23 AM
Sniper's Avatar
Level up: 5% Level up: 5% Level up: 5%
Level: 11 - 320 points to level up
Originally Posted by Chilly View Post
Theres plenty other things you can add for a blue look(such as specific types of antifreeze that are known not to break/kill stuff in loops, primochill g35 or w/e, I forget the brand atm), but ensure your using a dye that doen't seperate from the water. What happens often is the dye will seperate for one reason or another and "flake" into the rad, or a block or etc. And all we will see is a thread 2 months from now "where did the color in my loop go?"
lol yeah right on Chilly I get what you mean there for sure.
In a loop yes maybe so but this won't be "in the loop" right.
System #1 (in the works) Rampage II Extreme/ i920 - Stinger V8/ 6GB OCZ Tri Ch DDR3 PC-12800 Gold 8-8-8-24 1T - Corsair Dominator/
TRI SLI XFX 8800GTX 768MB - EK FC-8800GTX blocks/ Cooler Master 1250/ 150GB Raptor/ Supreme FX-II/ Pinnacle 24
System #2 P5QE-Deluxe/ E3110 45NM Xeon/ 4GB DDR3 PC-12800 OCZ Reaper/ SLI 7900GT's/ CoolerMaster 1250W/
Barracuda 500Gb 32mb/ X-Fi Extreme Gamer/ OCZ Laser mouse/ Zalman Theater 6M headphones/ 20.1" LG/ custom H2O in an H2gO
My Heatware R3
  #23 (permalink)
Old October 3, 2008, 11:48 AM
Level up: 77% Level up: 77% Level up: 77%
Level: 16 - 171 points to level up
Pricematch.. To be honest I'd rather get primochill tubing, yes they are colored, but are really good and are pretty good on bends, just get one of those tube coils.. You can get syringe locally for cheap..
I'm guessing your deciding to get worm type hose clamps from a local hardware store..
Crucial Ballistix PC2-8500 4GB, Saphire HD4870 512mb
Lian Li V1000, Enermax Galaxy DXX 1000W
WC Loop: Swiftech Apogee GT, Danger Den D5 Pump EK FC-4870 Nickel Block,
Swiftech Micro Reservoir
Black Ice GT Stealth 240 Rad w/Zalman ZM-F3
  #24 (permalink)
Old October 3, 2008, 12:20 PM
Sniper's Avatar
Yeah I was gonna go clear but they don't have it in my size only as a special order thing right. I suppose colored won't be so bad though. If it's better tubing that is.
My Heatware R3
  #25 (permalink)
Old October 6, 2008, 04:10 PM
Sniper's Avatar
Originally Posted by Linus@ncix.com View Post
If you want it really blue, just get a bottle of Feser View blue dye and add as much as you want.
If you want that GPU block, move fast. It'll be at least 2 weeks for more to come in and I think there's only 1-2 left.
Linus
Linus I see these are not available atm let me know when they will be if you can? Much appreciated. I have lots of time & don't mind waiting.
I've changed things up considerably as I'm now going with a diff plan. Saw something I liked & gonna try it out with a diff twist.
My Heatware R3
  #26 (permalink)
Old October 6, 2008, 04:23 PM
magictorch's Avatar
Level up: 96% Level up: 96% Level up: 96%
Level: 17 - 34 points to level up
I'd try and put metal barbs on everything-those bitspower barbs are very well made BTW-short thread is ideal for the GPU block. You seem to have ordered 2 sets which will cover the GPU block and either the radiator or res. Hopefully you've read about the issues with the EK4870X2 block-got to be careful with a couple of the screws and shorting-theyve included fiber washers now. The DD block is supposed to be a great fit and no reports of dead cards.
E6750 + Apogee GT block
DFI X38 LT
2x4870
74gb Raptor for OS, games
Thermalrock Dragon Case (sprayed black)
Loop 1: MCR 220 int. + cpu
Loop 2: MCR 320, Swiftech Res. +
2x EK FC blocks)
Pumps: 2x MCP655.
  #27 (permalink)
Old October 6, 2008, 04:52 PM
Sniper's Avatar
Yes I think I am going with alot of diff gear now lol. I'll update soon. Thinking about going with the bitspower compression fittings for anything inside the case & the reg bitspower barbs on everything otside the case if need be.
I'll have a look at that DD block cause I think i'm making an order from them anyways so might as well pick that up to along with my other stuff to. Thx.
My Heatware R3
  #28 (permalink)
Old October 7, 2008, 05:57 PM
Sniper's Avatar
Updated gear in first post. Just waiting to hear back about the case then start gathering parts.
My Heatware R3
  #29 (permalink)
Old October 7, 2008, 08:01 PM
Sniper get some real nice pics of that 4870 block, EK has always had an upper hand over DD blocks, but recently with that including GTX 280 and 4870x2 full cover blocks, DD has some pretty good finishing, and seem to have less problems than EK (shorting issue)..
And yeah ever since MpG, Vortex have started recommending Distilled water + nuke, and have also said it's cooler, I've been wondering if I really want to use that Feser stuff again.
  #30 (permalink)
Old October 7, 2008, 08:15 PM
Sniper's Avatar
Ah yeah? Must be good stuff then.
I'm going with the DD block mainly because of what I hear about it & that it's currently available as well. I'll be taking pics for a work log for sure though to.
My Heatware R3
