Old October 3, 2008, 08:07 AM
Sniper's Avatar
Level up: 5% Level up: 5% Level up: 5%
Level: 11 - 320 points to level up
Updated changed rad, barbs & added fans to the list.
Linus thx for the info. If it takes a couple weeks extra no biggy just gives me more time for extras like a new case hmmmm lol?
System #1 (in the works) Rampage II Extreme/ i920 - Stinger V8/ 6GB OCZ Tri Ch DDR3 PC-12800 Gold 8-8-8-24 1T - Corsair Dominator/
TRI SLI XFX 8800GTX 768MB - EK FC-8800GTX blocks/ Cooler Master 1250/ 150GB Raptor/ Supreme FX-II/ Pinnacle 24
System #2 P5QE-Deluxe/ E3110 45NM Xeon/ 4GB DDR3 PC-12800 OCZ Reaper/ SLI 7900GT's/ CoolerMaster 1250W/
Barracuda 500Gb 32mb/ X-Fi Extreme Gamer/ OCZ Laser mouse/ Zalman Theater 6M headphones/ 20.1" LG/ custom H2O in an H2gO
My Heatware R3
Old October 3, 2008, 08:11 AM
Level up: 77% Level up: 77% Level up: 77%
Level: 16 - 171 points to level up
Sniper, what are you planning to get both a Fill port and Res.. Just curious.. Oh and Dr.B is baaad.. he transferred a never ending virus to you :P
Crucial Ballistix PC2-8500 4GB, Saphire HD4870 512mb
Lian Li V1000, Enermax Galaxy DXX 1000W
WC Loop: Swiftech Apogee GT, Danger Den D5 Pump EK FC-4870 Nickel Block,
Swiftech Micro Reservoir
Black Ice GT Stealth 240 Rad w/Zalman ZM-F3
Old October 3, 2008, 08:22 AM
Sniper's Avatar
I figure I'll put the fill port in the top of the case & run it down to where ever I mount the Res as to not have to be in the case just to refill right. Seen a couple like that & liked the idea. Less chances of spill overs or what have you to right.
Yes you're right he is bad the frigger lol!
My Heatware R3
Old October 3, 2008, 08:34 AM
Yes you have a good plan.. I did that too, only difference my fillport is used for blocking the end of tube, which is just hanging outside the case lol..
Old October 3, 2008, 08:36 AM
Level up: 96% Level up: 96% Level up: 96%
Level: 13 - 23 points to level up
I wouldn't say the Dr. is bad...but definitely Evil lol. I was just starting a video card upgrade fund and then he starts waving that xfi around for sale lol. Fund started over
Amd FX60 @2.9
Asus A8R32-MVP Deluxe
2 Gig Corsair XMS 4000PT
2 Ati X1900's @XTX Speeds
2 WD 160gg HD's in Raid 0
XFi Platinum
Tt 680 Watt PSU
SATA Plextor DVD
(Liquid Cooled) Swiftech Apex Ultra and 2 MCW 60's
Kandalf
Old October 3, 2008, 08:56 AM
Sniper's Avatar
If I didn't already have a sound card I woulda been interested in that to lol.
I actually wanted to go with a DD drive bay res but they have to be mounted in that certain spot so aren't very versatile right. Swiftech res can be mounted anywhere really.
My Heatware R3
Old October 3, 2008, 09:26 AM
Bojamijams's Avatar
Level up: 60% Level up: 60% Level up: 60%
Level: 6 - 43 points to level up
Stay Away From Uv Dyes! Worst Thing You Can Add To Your Loop!
Old October 3, 2008, 10:16 AM
Level up: 80% Level up: 80% Level up: 80%
Level: 22 - 269 points to level up
swiftech pump + xspc top = no need for fill tube :D
CSE: Lian-Li PC-A70
MOB: Biostar T-Power I45
CPU: Intel C2D E8600 @ 4.3ghz
RAM: 4gb g.skill pc2-8000
GPU: XFX 8800 GT Alpha Dog Edition
PSU: PC Power & Cooling 750w
Heatware: My Heatware
  #19 (permalink)
Old October 3, 2008, 10:34 AM
Sniper's Avatar
Curious as to why this is? As I do not know why lol.
$5 filler+$1 tube = no need for expensive xspc top lol
It is a nice looking product though no doubt.
My Heatware R3
  #20 (permalink)
Old October 3, 2008, 10:42 AM
Chilly's Avatar
Level up: 19% Level up: 19% Level up: 19%
Level: 11 - 273 points to level up
Theres plenty other things you can add for a blue look(such as specific types of antifreeze that are known not to break/kill stuff in loops, primochill g35 or w/e, I forget the brand atm), but ensure your using a dye that doen't seperate from the water. What happens often is the dye will seperate for one reason or another and "flake" into the rad, or a block or etc. And all we will see is a thread 2 months from now "where did the color in my loop go?"
