Hey magic, what size of tubing are you using, and what kind ?
__________________ Intel E8400, Biostar TPower i45 Crucial Ballistix PC2-8500 4GB, Saphire HD4870 512mb Lian Li V1000, Enermax Galaxy DXX 1000W Samsung 931BW 19" LCD, Logitech MX Revolution WC Loop: Swiftech Apogee GT, Danger Den D5 Pump EK FC-4870 Nickel Block, Swiftech Micro Reservoir Black Ice GT Stealth 240 Rad w/Zalman ZM-F3 |
interesting... maybe larger volume and high speed of water will be improving whole temperature... right?
__________________ --- old: no brand silver case, 3g365p-ve, p4 2.6GHz HT, ga-8sq800 ultra, 1024 gb of generic ram (:oops:), MSI ti4200 8x 128mb, 520gb of HDD ( two maxtor and one seagate) and other NEW: cm 690, hx620, intel q9450, True Black, p5q deluxe, 2gbx2 ram of mushkin xp pc2 8500, evga 9800gx2. wd caviar se 16 640gb, 4x zm-f3 fans. |
I'm using 7/16ich tubing-musko something and the mighty MCP655 for good flow pressure. Also have NF P12s which Im not so sure about.
__________________ E6750 + Apogee GT block DFI X38 LT 2x4870 74gb Raptor for OS, games Thermalrock Dragon Case (sprayed black) Loop 1: MCR 220 int. + cpu Loop 2: MCR 320, Swiftech Res. + 2x EK FC blocks) Pumps: 2x MCP655. |
| Large volume only makes temperature changes happen more slowly, Max temp will still be the same just takes longer to get there. Faster flow will help as it will create turbulence in the water but that requires bigger pumps and most of the heat generated by the pumps goes into the water so it's somewhat self defeating. The gains are probably positive but suspect they're marginal provided the small pump is big enough. I use CPX-1's (which are considered pretty tiny) and I'm quite happy.
__________________ e3110 @ 4.14GHz w/ D-Tek Fusion Gigabyte GA-P35-DS3R rev.1 2x 2GB PC8000 Mushkin Redlines @ 920MHz w/5-5-5-12 timings Asus EN8800GT Top stock speed w/ DD Maze5 OCZ Gamer Xtreme 600W PSU Cooler Master Cosmos on water |
| I have a mixture of Swiftech and Masterkleer (that is probably what you have).. some big pieces.. I don't use it, just pay shipping, Ima send it to you.. Cheap.. ::)
Yes thanks for the offer Miggs, be glad to pay shipping . Just paid for the MCP 655 on Black_ice dragons's for sale post- so now have the gear needed for a loop dedicated to the GPUs only, just going to keep the cpu loop (vortex style with a MCR220) as is. Will start a work-log soon as the rest of the gear comes in.
| Thread Tools | |
| Display Modes | |
