Old September 27, 2008, 09:41 AM
FrankyG's Avatar
Default Thinking about whatercooling...
I was looking to whatercool my system would this stuff all work together ? or am I missing something ?
D-TEK Customs Fuzion V2 CPU Water Block S478/LGA775/S939/AM2/S754 1/2IN Barbs
Swiftech MCR320 Quiet Power Triple 120MM Water Cooling Radiator Black G1/4 Threaded + D-TEK Customs 1/2IN G1/4 Chrome High Flow Barb Fittings (Pair)
Swiftech MCP655 12V Industrial Water Cooling Pump 1/2IN Barbs
Danger Den Single Bay Reservoir 5.25IN 1/2IN Barbs
And 1/2 in tubing of course
Intel i7-5820K, MSI X99 SLI Plus, 16GB DDR4, Geforce GTX980
Old September 27, 2008, 09:47 AM
you will need hose clamp, juice, fan and maybee a radbox... and for what i read your reservoir is not a good one... a lot of people think the swiftech micro has bether.. or maybee a t-line
Old September 27, 2008, 09:50 AM
i forgot... look at my setup
ImageShack - Hosting :: 2709081111lo4.jpg
d-tek v2
swiftech 120.3
swiftech 655
t-line
i also use :
radbox
3x zalman f3 fan
5x ngear fan grill
distiled water with d-tek dye(alien green) and pt nuke
Old September 27, 2008, 09:52 AM
FrankyG's Avatar
ok so something like this ?
Swiftech MCRES-MICRO Clear HI-FLOW Water Cooling Reservoir 3/8IN & 1/2IN Barb Fittings
Swiftech Adjustable Black Hose Clamps for 1/2IN Inner Diameter 3/4IN Outer Diameter Tubing
Primochill Primoflex Pro LRT UV Red 1/2IN ID 3/4IN OD Tubing (10 Feet)
And 2 or 3 120mm fans
Old September 27, 2008, 09:59 AM
3 thing...
1: you need water additive
2: for hose clamp, i think the best choise is go to canadiantire and buy some plumber hoseclap(see on pcture of my setup) but it's me
3: maybee some metal brab for the swiftech reservoir..
but all in all i think you are good to go
what are you looking to cool? and what are your case?
Old September 27, 2008, 10:16 AM
FrankyG's Avatar
Looking to cool a Q9550 @ 3.8Ghz I had to over 4Ghz stable on air but too much heat so looking to go water. For a case i am using a Chieftec Dragon.
Old September 27, 2008, 12:13 PM
Phobia's Avatar
i would get metal barbs. Plastic ones can break as you're putting the tubing on, or taking it off. Plus, it goes on easier on the metal ones. You do not need water additive.. i've just used distilled water in 2 of my pc's and they've been fine. Just make sure you do not get anything Aluminum. Also, agreeing with someone who posted above, don't use those hose clamps. The ones where you tighten with a screw driver are awsome. NCIX sells, or used to sell them, they were called primo chill worm clamps. I cannot find them on the website now though.
(whitty saying to be plagiarized at a later date)
Old September 27, 2008, 12:36 PM
FrankyG's Avatar
Any hardware store carrys them
Old September 27, 2008, 12:59 PM
magictorch's Avatar
Looks good. You could always go 7/16th tubing to make you less reliant on clamps, cable ties will do fine with that tubing on 1/2 inch barbs. Also you'll need some distilled water and an additive like swiftech Hydrx to stop algae growth etc. I'd probably go with the swiftech Res as well-probably better for bleeding the loop.
Old September 27, 2008, 01:13 PM
FrankyG's Avatar
This is what I might order in the next couple weeks
Water Block: D-TEK Customs Fuzion V2 CPU Water Block S478/LGA775/S939/AM2/S754 1/2IN Barbs
Water Pump: Swiftech MCP655 12V Industrial Water Cooling Pump 1/2IN Barbs
Radiator: Swiftech MCR320 Quiet Power Triple 120MM Water Cooling Radiator Black G1/4 Threaded
Resevoir: Swiftech MCRES-MICRO Clear HI-FLOW Water Cooling Reservoir 3/8IN & 1/2IN Barb Fittings
Piping: Primochill Primoflex Pro LRT UV Red 1/2IN ID 3/4IN OD Tubing (10 Feet)
Fittings: 2x Swiftech 1/2IN OD Chrome Plated G1/4 Compatible Barb Fittings 1/4 BSPP (Set of Two)
