Old September 26, 2008, 11:01 PM
Default cleaning wc parts
ok guys that is my situation
i build a lowend wc system for my girlfriend.. but i was used primochill dye with pc pure.. so now all part(water block, rad, tubing, pump) are red.. that was ugly
soon i will upgrade the rad(already ordered) so at the same time i want to clean it..
the part was:
pump dx-1
rad swiftech 120.1
magicool water block
i already order some juice and tubing to replace the red one
so my question is.. what did you use to clean all parts?
maybee a product liquide to pump inside of all part to clean?
Thanks
Phil
Old September 27, 2008, 07:38 AM
biff's Avatar
I dunno about getting dye out but I use vinegar and salt to clean my parts. Some use ketchup which is basically the paste version.
Q6600 @ 3.83GHz w/ D-Tek Fusion
Asus P5Q-PRO
2x 2GB PC8000 Mushkin Redlines @ 1020MHz w/5-5-5-12 timings
EVGA GTX 280 (SC?)
OCZ Gamer Xtreme 600W PSU
Cooler Master Cosmos on water
Old September 27, 2008, 07:53 AM
i never think use vinegar and salt loll but i will try it
thanks a lot
and if anyone have another ''magic'' product let me know
Old September 27, 2008, 04:46 PM
biff's Avatar
FWIW I disolve 1 or 2Tbsp per liter of vinegar. Just to give you a heads up it will dull shiny copper surfaces if left sitting for an hour or two. So don't drop your newly lapped and polished WB in that solution and leave it over night.
Asus P5Q-PRO
EVGA GTX 280 (SC?)
