Old September 22, 2008, 11:04 AM
biff's Avatar
Default Got algae!!
I notice I got some algae in one of my loops. I'm going to be taking it apart to clean er up and make a change or two. I'm not really worried about the whole cleaning process, scrub the blocks, probably replace tubing for the price of it, but I'm not sure what to do with my micro-res'. I can't open them up to clean them and they're acrylic so they can get marked up pretty easy, plus I don't want to subject them to any nasty chemicals in case it clouds them up. Anyone have a nifty ideas on how to clean these?
i7 4790K @ 4.8GHz w/EK Supremacy Evo
MSI z97 Gaming 5
2x 8GB Gskill Sniper 2133 @ 2400MHz
EVGA GTX 280 (SC?)
OCZ Gamer Xtreme 600W PSU
Still rockin' the Cooler Master Cosmos on water
Old September 22, 2008, 11:27 AM
you may want to think about using more biocide like PT Nuke to prevent that.
Old September 22, 2008, 11:43 AM
zlojack's Avatar
Whatever you do, don't put alcohol on acrylic.
Old September 22, 2008, 11:44 AM
biff's Avatar
Thanks Professor! j/k
I used a homemade biocide which is the same as PT nuke, but obviously not enough. I was using distilled and the copper sulphate. One loop is fine but the other has started to go. It's the loop for my video maybe it being warmer might have made the difference. This time I think I'll go back to a touch of gool ol' glycol. I wanted to use some G11 just cause it's blue but can't find small quanities locally (Audi dealership will only sell 1 gallon) and I don't feel like ordering it out of the states (from Petras), I wouldn't want the UV dyes anyway. So I guess green it is... or maybe I'll try the pretty pink stuff! LOL
MSI z97 Gaming 5
EVGA GTX 280 (SC?)
Old September 24, 2008, 03:36 PM
biff's Avatar
As it turns out it wasn't algae but corrosion! I find it strange that one loop is crystal clear and the other loop went skunky and the only difference is the block used. One loop has a DD maze5 and the other a DTek fusion... weird. The inside of the maze was a lovely forest green. Everything cleaned up well and at least I'm in the 'putting back together' mode.
MSI z97 Gaming 5
EVGA GTX 280 (SC?)
Old September 24, 2008, 03:42 PM
Infiniti's Avatar
Wow.. Pics?
Old September 25, 2008, 07:18 PM
biff's Avatar
Sorry no pics. But Wait. It gets better!
I cleaned and rebuilt the GPU loop and left the cpu loop alone. Wanting to avoid this happening to the CPU loop though I did drain it and refill it with plain water to flush over night while leak testing the GPU loop. I drained out the top of the micro-res so no connections were touched. In the morning the GPU loop was confirmed leak proof but I'd lost a half a res worth on the CPU loop and was almost running the pump dry. WTF!? I found the rad was dripping wet. F'n Hell!! I thought during the work I must've dinged the core or something (though it still looked pristine) but I pulled that loop apart to find the leak and hopefully be able to solder it up. I drained and submerged the rad with hoses on so I could put some air into it and follow the bubbles... nothing. I then put the hose on the tap to run water through it and look for a damp spot figuring maybe its a crack or something and will slowly wick out... nothing. I plugged one tube and subjected the rad to pressure (what ever a thumb plugged tube is, maybe 20 - 30psi?) untill the tube blew off the faucet which was a hose adapter with a 5/8" barb so it was a tight fit.... still nothing!
This is probably the worst thing that can happen because I'll probably put it all back together and it won't leak and I'll be checking it 5 times a day for months!!
MSI z97 Gaming 5
EVGA GTX 280 (SC?)
Old September 25, 2008, 09:47 PM
u could replace ur water loop. lol
Old September 25, 2008, 09:49 PM
MpG's Avatar
MpG MpG is offline
How much copper sulphate did you add to the solution? I know copper sulphate is used for etching brass, which is what the tubes of your rad are probably made of. Any chance that a spot was weakened by an over-concentrated mixture (even though your pressure test came up nil)? PT_Nuke is two drops/litre max, remember.
Old September 25, 2008, 11:58 PM
Dashock's Avatar
Have you seen Biff's loop on the Cosmos case its mint just right with all those parts it matches.
Sucks btw Biff thats sooo odd. But dont worry i keep an eye on my computer since the first day i been watercooling lol i dont mind know im always impressed at how much ive learned over the past year thanks to you guys!!
Intel Xeon E3110 @ 3.0ghz-Then
Core 2 Quad Q9650 @ 3.8ghz-Now
PNY GTX 1050Ti (Coming)
Asus P5Q-E
Mushkin Ascent Redline 8000 8gb DDR2 @ 1066 5-5-5-15 2.05v
Corsair Cx600M
Samsung 850 Evo 250gb SSD
Noctua NfP-12's on Swiftech 320 rad
Logitech Z-625 setup
Sony X800E 43" 4K HDTV
Coolermaster Cosmos S/
