Do you don't, they actually don't make any contact with the cooler. I am not at home, I wish I could get you some pics (and all the pics I took are DEAD!! because maxupload decided to shut down.. crap).. But you only put the pads on what's shown in the manual.
__________________ Intel E8400, Biostar TPower i45 Crucial Ballistix PC2-8500 4GB, Saphire HD4870 512mb Lian Li V1000, Enermax Galaxy DXX 1000W Samsung 931BW 19" LCD, Logitech MX Revolution WC Loop: Swiftech Apogee GT, Danger Den D5 Pump EK FC-4870 Nickel Block, Swiftech Micro Reservoir Black Ice GT Stealth 240 Rad w/Zalman ZM-F3 |
ok great!
__________________ E6750 + Apogee GT block DFI X38 LT 2x4870 74gb Raptor for OS, games Thermalrock Dragon Case (sprayed black) Loop 1: MCR 220 int. + cpu Loop 2: MCR 320, Swiftech Res. + 2x EK FC blocks) Pumps: 2x MCP655. |
Any luck installing yet? Im still waiting for the pump before doing mine. Vortex told me the 3870 Ek blocks hes using have felt washers Really does make me wonder if EK has overlooked potential screw shorts with the 4870 block.Anyway I've cut some electrical tape to make some non-conductive washers and will hope for the best.
No I haven't really got a chance yet.. sorry.. I really hope they haven't starting not including stuff to cut down costs, would be really foolish from them.
Yea it does seem kind of odd and a little frustrating for such a well machined block. I should be ready to go on Friday. Im sure we'll be fine with that extra precaution .
Yea Sugar sent me some of those washers in the mail on Tuesday (thanks to him).. but it hasn't arrived yet, and my friend will be over tomorrow, so we will be putting the system up.. no washers.. oh nooezz...
| If it's not an X2 should be easy but if it is good luck finding an EK. you'll have to wait or go for the DD like I am. lol
__________________ System #1 (in the works) Rampage II Extreme/ i920 - Stinger V8/ 6GB OCZ Tri Ch DDR3 PC-12800 Gold 8-8-8-24 1T - Corsair Dominator/ TRI SLI XFX 8800GTX 768MB - EK FC-8800GTX blocks/ Cooler Master 1250/ 150GB Raptor/ Supreme FX-II/ Pinnacle 24 System #2 P5QE-Deluxe/ E3110 45NM Xeon/ 4GB DDR3 PC-12800 OCZ Reaper/ SLI 7900GT's/ CoolerMaster 1250W/ Barracuda 500Gb 32mb/ X-Fi Extreme Gamer/ OCZ Laser mouse/ Zalman Theater 6M headphones/ 20.1" LG/ custom H2O in an H2gO My Heatware R3 |
| Thread Tools | |
| Display Modes | |
