Old September 19, 2008, 08:27 AM
Skyllz's Avatar
Default How big of a rad do I really need?
I want to watercool my Q6600 and my 3870 just so I can enjoy silence again since my computer is in my TV room.
Is a single 120mm rad sufficient? Should I look into a 2X120mm sized rad?
I do game, I dont overclock, it's stricly for the quiet part and I feel like screwing around with this that I am looking into watercooling. This would be my first watercooling kit. I do bring my rig sometimes to LAN parties too.
I dont plan on upgrading my computer for a while too(1 year at least).
Thanks for any recommendations.
Skyllz's Avatar
I was looking mainly at this BTW. Not from this shop but this kit + that cooler.
Single
Swiftech H20-120 Compact 3/8IN Single 120MM CPU Liquid Cooling Kit - DirectCanada
Double
Swiftech H20-220 Compact 3/8IN Dual 120MM CPU Liquid Cooling Kit - DirectCanada
VGA Block
Zalman ZM-GWB3850/3870 3850 3870 GPU Waterblock - DirectCanada
Old September 19, 2008, 08:41 AM
Varroa's Avatar
I used the H20-120 on my FX-60 and it was barely able to cool just the cpu. I had to upgrade the rad to get sufficient cooling out of it. I now use the H20-120 with the theromchill 120.1 rad and a noctua fan on my 8400 and it does a good (but not great) job of cooling the cpu alone and is quiet. I have a second loop for the video card and NB. I don't think a H20-120 would do a good job on the CPU and video card. Go for the H20-220 if you are going to do both and switch the fans to noctua to go quiet. The rad in the 220 is what I am using to cool my 2900XT and the NB and it does a good job and considering the 2900XT is a 150-160watt GPU then I would say the rad can handle your videocard and CPU.
GAMER: Win7 Pro x64, I7 3770 (stock) (CM 212+), Asus P8Z77-V Pro, XFX 6950 2GB, Corsair Vengeance LP 4 x 4GB DDR3 1600Mhz, Crucial M4 120 GB + 256GB, Intel X25-M 160GB, 1TB WD Blk, DVD, BRD, HX750W, Auz X-Fi Prelude, Intel Pro CT Gbit NIC & CM Cosmos
Game Server: Win7 Pro x64, AMD Phenom II X4 960T Zosma, Gigabyte GA-MA770-UD3, 2x2GB Gskill DDRII 1000, 640GB WD Blk, 1 ODD, Asus 9600 GSO, Intel Pro PT Gbit, Corsair 400W PS & Antec 300.
Old September 19, 2008, 09:59 AM
Bojamijams's Avatar
You definetly want a 2x120. Look at the Swiftech 220 rad. Cheap and will do you just fine.
Old September 19, 2008, 10:19 AM
swiftech 220 is a great rad. Keeps my 8600 cool when under load.
Old September 19, 2008, 11:03 AM
Bojamijams's Avatar
Even the 320 is quite cheap (compared to the overpriced PA120.3) and will give you little better performance if you can fit it. Also room for expansion later.
Old September 19, 2008, 11:04 AM
cdn_Madrach's Avatar
I use one to cool my Fx 60 and 2 1900's in crossfire no problem. does a great job.
Intel e8400
Asus P5q pro
Mushkin Redline 4gb
Silverstone Strider 1kw modular
4870x2
Ocz Vendetta 2
Top deck Tech Station
Samsung dvd
Old September 19, 2008, 11:33 AM
Cptn Vortex's Avatar
320 will be more than enough, and even more room to expand. For $50, why not.
The Vortex H20
MSI Z77A-GD65
Intel i7 3770K @ 4.6GHZ 1.28v
Galaxy GTX 680 @ 1241MHZ
8GB Mushkin Blackline 1600MHZ 9-9-9-24 1.5v
Asus Xonar Essence STX
OCZ Z-Series GOLD 850W
2 x 128GB Corsair Force GT SATA3 SSD RAID0 :)
Acheiva Shimian Q270 Lite 2560x1440
Benq W500 Pojector.
Watercooling:
EK Supreme HF, EK FC GTX 680 Block, MCR320+Gelid Silent 12 Push/Pull, DD Pump, EK Multioption 100ml Res, EK Coolstream XT 220 RAD Gelid Wings Push/Pull.
Old September 19, 2008, 02:14 PM
"Quote This..."
I have the 220 on my q6600 + 4850 all overvolted and overclocked. Works perfect. In fact while I was testing the 4850 I just had the cpu wb attached and the cpu was no cooler without the gpu in the loop.
Old September 19, 2008, 03:33 PM
the VGA is aluminium...
