  #21 (permalink)
Old April 24, 2007, 01:22 PM
Patriote's Avatar
Just had a look in everest. I get 5 Degrees difference from the temperature inside my case and in my room. So, is not that bad
- Asus P8Z68-V PRO
- Intel I5 2500k @ 4.5Ghz
- Asus Geforce 580GTX DirectCUII Fermi
- 16GB Corsair Vengeance Low Profile
- Ultra X3 1000 Watt
- Asus Xonar DX 7.1 \ Klipsch Promedia 2.1 THX
- Corsair Vengeance 1300 Gaming Headset
- Crucial M4 SSD 128GB \ WD Caviar Black 1TB
- CoolerMaster 690II Advanced
- Dell UltraSharp 24''
- Noctua NH-D14
  #22 (permalink)
Old April 24, 2007, 01:34 PM
...yah! That is the bottom line...what temp do you get with Core Temp 0.95 when 100% loaded?
Intel Core 2 Quad QX6700 OC 3.6GHz
Mobo D975XBX2, 4GB DDR2 800 MHz Corsair TWIN X Dominator
4X 36GB Raptor in RAID 0 (on Intel controller with dual Boot Win32 Pro)
3X 360 GB Seagate No RAID (on Marvell controller for Apps, Paging and Back up)
EVGA GeForce 8800GTS Dual DVI- 2x Monitors 24'' 1920 x 1200
Water Cooling, Ultra X3 1000 Watts PWS.
ASUS Laptop G2S T7700 @ 2.4GHz
  #23 (permalink)
Old April 24, 2007, 01:37 PM
Babrbarossa's Avatar
No- that's a pretty darned good temp!
Francois- if you're thinking oabout setting up your own, you could also consider a top mount.
You've probably seen pics of mine, but sswilson has an external top-mount that works really well and might be easier to set up- also might want to check out Cdn Madrach's rear-mount. You can find these in the Case Pics thread
  #24 (permalink)
Old April 24, 2007, 01:46 PM
...thankx for the info.
...I am still learning!
  #25 (permalink)
Old April 24, 2007, 01:47 PM
Patriote's Avatar
It never goes over 48 Degrees 100% loaded for 3hours at 3.6Ghz.
Thats when i was Testing for stability on my E6600. About a month ago or so.
Temps after 12hours of stressing at 3.6Ghz
3.6Ghz idle temps.
E6600 at stock idle temps.
3.6Ghz 100% loaded for 3hours.
EDIT: At that time i used coretemp 0.94 Beta.
- Asus P8Z68-V PRO
- Noctua NH-D14
  #26 (permalink)
Old April 24, 2007, 01:55 PM
Deathspawner's Avatar
What is your CORE TEMP 0.95 reading after 10 minutes of 100% load?
I'll test tonight... the ambient heat is high right now (85F).
Originally Posted by Patriote View Post
Do you have some pics of your set-ups m8 ?
Sure. Here is my general setup during the day... surrounded by two desks to maximize workflow. You can see the first Nautilus there. Here are the other two, hidden behind the desk that I pulled out.
That's a thorough guide man!
Techgage.com | Editor in Chief
Intel Core 2 Quad Q9450 @ 3.20GHz, ASUS P5K Premium WiFi-AP, OCZ 8GB PC2-6400, EVGA GTX 285 1024MB
Seagate 500GB, 750GB & 1TB, Pioneer 22x ODD, Corsair 1000HX, Thermalright Ultra-120, CM Storm Sniper
Dell 2408WFP 24", ASUS Xonar Essence STX, Ultrasone PRO 750, Gentoo Linux (KDE 4.4, 2.6.32 Kernel)
"Take care to get what you like, or you will be forced to like what you get!" - H.P. Baxxter
Profiles: Last.fm | Xbox Live | Steam
  #27 (permalink)
Old April 24, 2007, 01:58 PM
I am convince...I have to go WC!
  #28 (permalink)
Old April 24, 2007, 02:05 PM
Patriote's Avatar
Check it out. 3.6Ghz and temps with Everest Ultimate Edition and Coretemp 95. Just took the screenshot!
Deathspawner : OMG! Me want more pics! I love the LCD's all around the place! LOL!
Oh and i have a Lexa too!
- Asus P8Z68-V PRO
- Noctua NH-D14
  #29 (permalink)
Old April 24, 2007, 02:15 PM
...I can't see well, the resolution of your picture is too low!
  #30 (permalink)
Old April 24, 2007, 02:18 PM
Patriote's Avatar
lol click on little pic and it'll send you on a site where it's hosted. Then when you see it there, click on it so it gets in 1600 x 1200 and not your monitor size. That way you'll be able to see all the details
- Asus P8Z68-V PRO
- Noctua NH-D14
Corsair 520HX enough for me? curtispan Power Supplies 7 January 6, 2008 07:55 PM
Corsair TX750W Cptn Vortex Power Supplies 5 November 4, 2007 10:55 AM
Virtual Hideout reviews Corsair Nautilus GPU waterblocks Babrbarossa Reviews & Articles from the Web 0 March 8, 2007 08:43 AM
Corsair XMS2 Babrbarossa RAM 4 January 28, 2007 10:07 PM
