  #41 (permalink)
Old October 2, 2008, 10:59 AM
3.0charlie's Avatar
Originally Posted by Dr_BenD_over View Post
Am I going to need plugs for the block, or are they included?
Fittings can be used on both side of the block (up and down), the 2 plugs are enclosed
From NCIX.
Main: GA-X58-Extreme - i7 920 - TX750W - Raptor - 3Gb DDR3-1333 Triple-Channel - GTX260 SLI'ed - TRUE - P182
HTPC: M3A78-EM - 5000+ X2 - HX520W - 'cuda 1Tb - XP2-5300 2x512Mb - 9800GT - SI-128 - Prelude - Moneual 932B
  #42 (permalink)
Old October 2, 2008, 11:21 AM
Level up: 77% Level up: 77% Level up: 77%
Level: 16 - 171 points to level up
Yup, you should have 2 plugs included with the block.
Crucial Ballistix PC2-8500 4GB, Saphire HD4870 512mb
Lian Li V1000, Enermax Galaxy DXX 1000W
WC Loop: Swiftech Apogee GT, Danger Den D5 Pump EK FC-4870 Nickel Block,
Swiftech Micro Reservoir
Black Ice GT Stealth 240 Rad w/Zalman ZM-F3
  #43 (permalink)
Old October 2, 2008, 11:32 AM
zlojack's Avatar
Level up: 75% Level up: 75% Level up: 75%
Level: 15 - 166 points to level up
Hey Apollo4g, did you get those MCW60's mounted?
Any pics?
MM H2GO ~ GA-X58-UD5 ~ i7 920
4GB OCZ Gold Edition DDR3-1600GHz ~
~ Soundblaster Fatal1ty XtremeGamer Pro ~ Samsung SyncMaster 245b 24"
2 WD Raptor 150 GB (RAID0)/ WD Caviar 500 GB ~ Samsung DVD/RW ~ Vista Ultimate 64
  #44 (permalink)
Old October 2, 2008, 11:37 AM
Dr_BenD_over's Avatar
Level up: 41% Level up: 41% Level up: 41%
Level: 10 - 167 points to level up
From NCIX.
I know, I'm blind
|Q6600 at 3.0|Diamond HD4870X2|G.SKILL PC2-6400-2x2048|P5Q Deluxe(0803)|1.866TB|XFiXM|245B|AL1916W|
Folding? If you're not doing it, you should ask about how to.
