Yeah I've seen those Bitspowers on a different forum, now if I could remember where... damn.. pretty good quality. edit: yes those are the ones ^^
__________________ Intel E8400, Biostar TPower i45 Crucial Ballistix PC2-8500 4GB, Saphire HD4870 512mb Lian Li V1000, Enermax Galaxy DXX 1000W Samsung 931BW 19" LCD, Logitech MX Revolution WC Loop: Swiftech Apogee GT, Danger Den D5 Pump EK FC-4870 Nickel Block, Swiftech Micro Reservoir Black Ice GT Stealth 240 Rad w/Zalman ZM-F3 |
hmmmm lol I've wanted to go H2O for awhile now & looks like I have a reason now what? Nice setup Dr. I think in the next week I might be doing the same but different. Like to keep my options open for adding at a later date.
__________________ System #1 (in the works) Rampage II Extreme/ i920 - Stinger V8/ 6GB OCZ Tri Ch DDR3 PC-12800 Gold 8-8-8-24 1T - Corsair Dominator/ TRI SLI XFX 8800GTX 768MB - EK FC-8800GTX blocks/ Cooler Master 1250/ 150GB Raptor/ Supreme FX-II/ Pinnacle 24 System #2 P5QE-Deluxe/ E3110 45NM Xeon/ 4GB DDR3 PC-12800 OCZ Reaper/ SLI 7900GT's/ CoolerMaster 1250W/ Barracuda 500Gb 32mb/ X-Fi Extreme Gamer/ OCZ Laser mouse/ Zalman Theater 6M headphones/ 20.1" LG/ custom H2O in an H2gO My Heatware R3 |
That loop will be good for the X2. I think you get around 1 litre of the primochill, that will be just about enough when you include the RES. With an MCR220 integrated and an apogee GT block I used about 600ml. If you've got your heart set on black coolant then stick with it. Personally I like the Hydrx additive which you mix with distilled water-although it is green which is not to everyones tastes.
__________________ E6750 + Apogee GT block DFI X38 LT 2x4870 74gb Raptor for OS, games Thermalrock Dragon Case (sprayed black) Loop 1: MCR 220 int. + cpu Loop 2: MCR 320, Swiftech Res. + 2x EK FC blocks) Pumps: 2x MCP655. |
That looks quite well Dr.B.. Personally I'd spend a dollar or two more and get the D-Tek barbs, a bit better and secure.
| Quote:
D'oh, added the wrong ones, no wait, NCIX doesn't have the DTek ones in 3/8
__________________ |Q6600 at 3.0|Diamond HD4870X2|G.SKILL PC2-6400-2x2048|P5Q Deluxe(0803)|1.866TB|XFiXM|245B|AL1916W| Folding? If you're not doing it, you should ask about how to. Last edited by Dr_BenD_over; October 2, 2008 at 09:20 AM. |
You don't have your GPU cooler on the list? Black coolent eh? cool.
| Quote:
__________________ |Q6600 at 3.0|Diamond HD4870X2|G.SKILL PC2-6400-2x2048|P5Q Deluxe(0803)|1.866TB|XFiXM|245B|AL1916W| Folding? If you're not doing it, you should ask about how to. |
Am I going to need plugs for the block, or are they included?
Nice MS paint loop configuration....should be a solid WC loop when its all said and done....I liked the idea of the empty APC case it got me thinking about all these dead BE500's I have laying around.
__________________ _______________________________________________ E8600 420x10 |Thermalright 120 Black | Maximus Formula | ATI 4870X2 | 4GB Buffalo FireStiX PC8500 | Corsair HX1000 | Lian Li V2010B | Vista Ultimate 64bit 3D Mark 06 - 20079 Q6600 334x9 |Thermaltake Blu Orb | ASUS P5Q-PRO| ATI 2900XT | 6GB Corsair XMS2 PC6400 | Corsair HX520 | Lian Li V600B | Vista Home Premium 64bit 3d Mark 06 - 12775 Last edited by cwestwell; October 2, 2008 at 11:09 AM. |
| Thread Tools | |
| Display Modes | |
