Just in case you didn't catch it - looks like the DD block is $10 bucks off right now at NCIX. Every little bit helps, right?
__________________ QX9650 @ 4.038GHz (425x9.5) | Asus Formula Maximus | GTX280 (777/1620/1404) | Mushkin XP2-8000 Redline 2x2GB Q6600 @ 3.6GHz (400x9) | MSI P35 Platinum | 8800GTS 640MB (700/900) | Mushkin EM2-6400 2x2GB |
Nice. You might post a few pics for posterity, since I've seen that question come up more than a few times. Also at issue is exactly what else on that card needs bits of metal stuck to it for cooling. If there was ever a card in desperate need of a Uni-sink...
| Quote:
__________________ |Q6600 at 3.0|Diamond HD4870X2|G.SKILL PC2-6400-2x2048|P5Q Deluxe(0803)|1.866TB|XFiXM|245B|AL1916W| Folding? If you're not doing it, you should ask about how to. |
| NCIX.com - Buy Ek Water Blocks EK-FC 4870 X2 - CF Nickel Full Cover Radeon HD 4870 X2 GPU Block G1/4 - 3830046993571 In Canada. Quote:
__________________ Main: GA-X58-Extreme - i7 920 - TX750W - Raptor - 3Gb DDR3-1333 Triple-Channel - GTX260 SLI'ed - TRUE - P182 HTPC: M3A78-EM - 5000+ X2 - HX520W - 'cuda 1Tb - XP2-5300 2x512Mb - 9800GT - SI-128 - Prelude - Moneual 932B |
Might be worth waiting it out and getting that EK block, very well designed and looks real good.
__________________ E6750 + Apogee GT block DFI X38 LT 2x4870 74gb Raptor for OS, games Thermalrock Dragon Case (sprayed black) Loop 1: MCR 220 int. + cpu Loop 2: MCR 320, Swiftech Res. + 2x EK FC blocks) Pumps: 2x MCP655. |
Excellent, the notify when available thing worked, EK block ordered.
| Ever think of using a 90 barb on the 2 inside ports so you don't need to do any magical bendy tube magic? |_---_| ? This is the route I think I will go when I finally watercool my 2x 4870x2 cards Also on an unrelated note... I was like "hum, his name is very familar", then I kept surfing my other frequently visited sites... I see you EVERYWHERE, your on redflagdeals, xtremesystems, and the one that pop'ed into my head as "NOW I KNOW WHERE I KNOW HIM FROM!"... NCIX Fourms. Last edited by Chilly; October 1, 2008 at 01:36 PM. |
| NCIX.com - Buy Koolance Single G1/4 Swivel Angled 1/2 Inch Threaded Compression Fitting - NZL-L13KG1 In Canada. NCIX.com - Buy Bitspower Single G1/4 Swivel Angled 1/2IN Barb Fitting for 1/2 Inch ID Tubing - BP-LRI In Canada.
| Thread Tools | |
| Display Modes | |
