Old September 18, 2008, 05:18 AM
Dr_BenD_over's Avatar
Level up: 41% Level up: 41% Level up: 41%
Level: 10 - 167 points to level up
This is what I have in my shopping cart right now.
Swiftech MCP350 12V Industrial Water Cooling Pump 3/8IN Barbs
Swiftech MCR220 Quiet Power Dual 120MM Water Cooling Radiator Black G1/4 Threaded
Swiftech MCB-120 Radbox Revision 2 Black
Swiftech MCR220-QP-RES Quiet Power Dual 120MM Water Cooling Radiator & Integrated Reservoir G1/4
Clearflex 60 Tubing 3/8IN ID 5/8IN OD 10 Feet
Primochill 3/4IN ANTI-KINK Tube Coils - for 3/4 Inch OD Tubing - Gloss Red
Swiftech 3/8IN OD Chrome Plated G1/4 Compatible Barb Fittings 1/4 BSPP (Set of Two)
Feser One Feser View Red UV Reactive Dye Water Additive 50ML Bottle
I'll need to find the block in stock somewhere (with 3/8 barbs) and I'm thinking I can pick up distilled water in a drug store, or should I use something else?
|Q6600 at 3.0|Diamond HD4870X2|G.SKILL PC2-6400-2x2048|P5Q Deluxe(0803)|1.866TB|XFiXM|245B|AL1916W|
Folding? If you're not doing it, you should ask about how to.
Old September 18, 2008, 05:42 AM
Level up: 38% Level up: 38% Level up: 38%
Level: 6 - 66 points to level up
change your anti-kink for 5/8 one... also you have 2 rad.. keep the second one.. and dont forget hose clamp
Old September 18, 2008, 06:23 AM
sswilson's Avatar
Super Moderator
Distilled water would be fine, but pick up some petra nuke or a similar biocide to prevent algae. Just make sure to check the distilled water to ensure that it's got as much of the mineral content as possible removed. Some of the distilled waters look like they actually add minerals.... :)
And yeah.... why the two rads?
Gigabyte P35-DQ6 / E8400 / 2X2 Gig Mushkin PC2 8500 Ascents / Corsair TX750W PSU / Gigabyte 8800GTS / CoolerMaster Cosmos S / MCP655 WC Pump / MCR320 Rad / 6X Yate Loons / PA120.1 / 2X Scythe Ultra Kaze / Swiftech Apogee GTZ WB / Samsung 2253BW
ASUS P5Q Pro / Q6600 / 2X1 Gig Supertalent PC2 6400 / PC P&C 750W Silencer / HIS 3870 IceQ3 / HT Omega Striker 7.1 / MCR220-QP-Res / DD DDCPX-Pro / Apogee GT / Swiftech MCW30 / Highspeed PC Tech Station / Samsung 931BF
Old September 18, 2008, 06:54 AM
My bad, forgot to remove the second one.
Old September 18, 2008, 07:42 AM
3.0charlie's Avatar
Keep the second one, or add a reservoir.
Main: GA-X58-Extreme - i7 920 - TX750W - Raptor - 3Gb DDR3-1333 Triple-Channel - GTX260 SLI'ed - TRUE - P182
HTPC: M3A78-EM - 5000+ X2 - HX520W - 'cuda 1Tb - XP2-5300 2x512Mb - 9800GT - SI-128 - Prelude - Moneual 932B
Old September 18, 2008, 08:52 AM
matsta31's Avatar
Level up: 49% Level up: 49% Level up: 49%
Level: 12 - 209 points to level up
or use a t-line and dont worry about any reservoir. T-Line air bubble bleeding is really longer than with a reservoir (I would say 5 to 10 times longer) but I really find managing a T-Line is an easier overall process. This is more of a personnal choice, you'll have to experience it for yourself.
Dont forget to leak test your stuff before going live :)
QX9650 @ 4.1 - Fuzion V2 - PA 120.3
DFI - LANPARTY DK P45-T2RS +
2 X 2 Gb Redline
Seagate 320G
BFG GTX280
Q6600 - Asus Maximus - 2 x 1 Gb OCZ Reaper - seagate 1Tb
Old September 18, 2008, 10:11 AM
Primochill 1/2IN ANTI-KINK Tube Coils - for 1/2 Inch OD Tubing - Gloss Red
Primochill Reusable Red Hose Clamps for 1/2 Inch Outer Diameter Tubing (2 Pack) x5
Primochill Primoflex Pro LRT Clear 3/8IN ID 1/2IN OD Tubing (10 Feet)
Feser One Fluid UV Black NON-CONDUCTIVE Water Replacement for Liquid Cooling
DD-4870-X2 Water Block with 3/8 fittings
Old September 18, 2008, 11:30 AM
Level up: 77% Level up: 77% Level up: 77%
Level: 16 - 171 points to level up
Nice list, good move on the tubing from Clearflex to Primochill, a little expensive but it is worth it. I was hoping EK had their blocks for X2 released or in stock, usually better than the DD ones.
As for barbs, those Swiftech ones aren't bad, but a better choice NCIX.com - Buy D-TEK Customs 3/8IN G1/4 Chrome High Flow Barb Fittings (Pair) - 3/8-inch-barb-pair In Canada. D-tek ones, just a dollar more, but very good quality..
  #19 (permalink)
Old September 18, 2008, 12:38 PM
Thanks everybody. I'll probably hold off a week or two to see if any more blocks come out. I'll be sure to take some pics for the watercooled gallery ;)
  #20 (permalink)
Old September 18, 2008, 02:24 PM
Yea, oh and Dr. B, according to NCIX if you order those EK 4870x2 blocks, they take 2-4 business days, now how true is that I have no idea, they are about $170.00. NCIX.com - Buy Ek Water Blocks EK-FC 4870 X2 - CF Nickel Full Cover Radeon HD 4870 X2 GPU Block G1/4 - 3830046993571 In Canada.
