Old September 17, 2008, 06:15 AM
Varroa's Avatar
Default Socket A watercooling
Hi Guys, I recently dug up some old parts and put together a watercooled Socket A system to fold on (Asus mobo, Athlon XP-M @ 2.4 Ghz, 2 gigs DDR ram and ATI 3650 AGP). I had everything I needed except for the video card and the waterblock. I searched the web and bought a socket A waterblock, pump and the video card. I threw it all together and it is running fine except for one problem. I think the CPU waterblock it too restrictive for the pump. The pump I have is a Danger Den DD-CPX1. When the system is running the pump pushed the fluid up to the CPU block (filling the tube) but only a trickel comes out the otherside of the block (tube is only about 1/8 full) . I can't remember the model of the CPU block but it has an acrylic top. Could the pump be too weak for the CPU block? Are there less restrictive socket A blocks available that I could use instead? Thanks.
GAMER: Win10 Pro x64, I7 3770K (4.7Ghz) (corsair H110i), Asus P8Z77-V Pro, EVGA GTX 1080 FTW, Gskill 2 x 8 GB DDR3 1600Mhz, Crucial M4 120 GB + 256GB, Crucial M500 480 GB SSD, Mx 500 SSD, HX750W, Sound blaster Z, & Fractal Design Arc MIDI R2
Lenovo Ideapad Y510p: i7-4700MQ 2.4GHz (undervolted by 80mV), 16GB DDR3L-1866MHz, Intel GMA 4600HD / SLI'ed Nvidia Geforce GT 755M 2GB GDDR5, 240 GB Crucial SSD, 128GB M.2 SSD, 15.6" HD+ Glossy LED
Old September 17, 2008, 10:30 AM
ebdoradz's Avatar
d-tek fusion V1 can be mount on a socket A board if you have the 4 holes
Gigabyte GA-MA790XT-UD4P / AMD Phenom II x3 720BE @ x4/ Crucial Ballistic DDR3 / Sapphire 4830 512mb / Corsair 620W PSU / 2*80GB Seagate
DFI LP nF4 Ultra-D / AMD Opteron 165 @ 2.7Ghz/ 2*1GB OCZ Gold GX XTC / Sapphire X1950XT / Fortron 450W PSU / 2*Maxtor 80Gb
Old September 17, 2008, 10:31 AM
Dashock's Avatar
have a look at the inside of the block might be sum gunk build up was is a new socket A block???/
Intel Xeon E3110 @ 3.0ghz-Then
Core 2 Quad Q9650 @ 3.8ghz-Now
PNY GTX 1050Ti (Coming)
Asus P5Q-E
Mushkin Ascent Redline 8000 8gb DDR2 @ 1066 5-5-5-15 2.05v
Corsair Cx600M
Samsung 850 Evo 250gb SSD
Noctua NfP-12's on Swiftech 320 rad
Logitech Z-625 setup
Sony X800E 43" 4K HDTV
Coolermaster Cosmos S/
Old September 17, 2008, 10:35 AM
ebdoradz's Avatar
been think to watercooled my nf2 rig,
that DFI nF2 baord was bought new 2 years ago and the compoter have been turned on less then 75 times....
maybe i could watercooled it and keep it until it worth half million
Old September 17, 2008, 10:36 AM
Not to discourage, but tbh it isn't water cooling a Socket A processor, a good heatsink will do almost enough justice as water cooling will.
Old September 17, 2008, 10:43 AM
Varroa's Avatar
The block was brand new and with the acrylic top I can see inside and I don't see any blockages (but I will look again, maybe something was in the lines and got stuck in the block). The board is a A7N 8x E Deluxe board with a NF2 chipset. I guess I will have to just look and see.
Old September 17, 2008, 10:50 AM
Varroa's Avatar
Looks like it does has the 4 holes, interesting:
Old September 17, 2008, 10:52 AM
ebdoradz's Avatar
maybe you barbs are a bit long and they are almost touching the copper base of the block, that would n't allow enought water to pass
Old September 17, 2008, 10:56 AM
Varroa's Avatar
I had that problem on a full coverage video block once, I will check it out, thanks!
Old September 17, 2008, 07:04 PM
Varroa's Avatar
Ok, I fixed the problem but I am not sure what I fixed. I pulled the CPU block out (it was pretty easy considering there was air on both sides of it) and took it completely apart. There was no blockage and the barbs were not long enough to go all the way through the plexi. Put it back together and turned it on and it was still the same. I then pulled the pump out, flushed it with water and put it back together and now it works like a charm! Flow is great and temps dropped 10c. Must have been something in the pump but who knows.
