Old September 15, 2008, 04:38 PM
matsta31's Avatar
ok then block is either fusion v2 (the one I prefer) or GTZ.
For additive I dont remember but it was in the instructions that came with it. Here what petra reccomend with their nuke :
NCIX.com - Buy Pts Petra PT_NUKE Concentrated Biocide Water Additive for Water COOLING(10ML) - NUKE-10 In Canada.
you can also use hydrx :
NCIX.com - Buy Swiftech Hydrx Water Additive Coolant 2 oz Bottle - HYDRX2OZ In Canada.
Sold hardware again.....
Currently using WHS hardware....
Old September 15, 2008, 04:39 PM
MpG's Avatar
MpG MpG is offline
For PT_Nuke, 1 drop per liter. Two drops/liter, maximum. You don't need any more, and the stuff is actually fairly acidic.
Old September 15, 2008, 04:54 PM
thank for the reply guys..
swiftech hydrx are out of stock or low stock for the moment...
and for petra nuke how many drop in one bottle(10ml)??
Old September 15, 2008, 06:26 PM
MpG's Avatar
MpG MpG is offline
Lots. I've gone through at least 5-6 liters of coolant in my one system, at about 1.5 drops/liter, and the bottle is still 3/4 full.
Old September 15, 2008, 06:50 PM
i see on ncix primochill feser one and d-tek have dye.. what will be the best match for distiled water and petra nuke??
Thanks
Phil
Old September 15, 2008, 09:24 PM
hey man, PM the feser fluid with NCIX from DC to $10. NCix sells for $20, and i find it cools better then the primochill coolant
Old September 16, 2008, 05:51 AM
JD JD is offline
Thanks
Phil
If your adding dye + additives, you might as well just buy pre-mixed coolant...
