UPDATE:
Thanks a lot for all of your responses, I bought a D-tek Fuzion V1 off someone here. It was exactly as you guys said... the CPU block was the limiting factor mostly and I'm very satisfied with my results now.
Before: Q6600 @ 3.2ghz with Swiftech Storm Rev. 2 --> Full load temps = high 60s/low 70s
After: Q6600 @ 3.6ghz with D-Tek Fuzion V1 --> Full load temps = low-mid 50s
I may think about getting a better pump but probably not for awhile, I'm more than satisfied with these results.
I'd like to thank all of you who replied to my post and gave me some helpful and prompt advice!!
