Old September 6, 2008, 10:00 AM
Originally Posted by DavidDemise View Post
::EDIT::
Correction, now It WONT bump up, even in games.
And at standard clocks as-well.
guys, i think his issue is that the mhz arnt ramping up, even when using 3d.
vista 64 on these rigs
Q9450 @ 3.5Ghz | E8400 @ 4.2Ghz
8gb Muskin Redline. | 2gb Kingston Hyperx
________________________________|_________________ ______________
EVGA 780i FTW ----\--||___||--/---- EVGA 780i SLI
Antec TP Quatro 1000W \ :==^==: / Antec TP Quatro 850W.
Nvidia 9800 GX2 X 2 SLI \|--o--|/ Nvidia 8800 GTS X 2 SLI
1X 500GB Western Digital. \_____/ 3X 150GB WD RAPTOR RAID-0
Old September 6, 2008, 10:21 AM
Supergrover's Avatar
Originally Posted by SKYMTL View Post
Here is what happens:
When the card is in 2D use the clock go down as a heat and power savings measure
When you OVERCLOCK using Rivatuner, you have the choice to overclock 2D or 3D clocks. Personally, what I do is ONLY overclock 3D but if you use default overclocking then both 2D and 3D clocks will increase. I personally like having power savings when in 2D and then all the power I want in 3D but what you do is up to you.
Ditto
I see no need to be running a overclock while not in 3d.
R.I.P.
