Old September 2, 2008, 08:27 PM
Jim's Avatar
Jim Jim is offline
Default card needed for tv only
need a video card for use with a 720p tv will be playing vids from torrent files ( tv shows that kinda thing,no hi def content,no gaming ability necessary) not refering to a tuner card ether ,HDMI needed I guess? just somethin that'll give great picture,recommendation?
thanks
Shooter-Gigabyte GTX 660 Ti OC,G.SKILL Ripjaws 8 gigs DDR3-1600, Phenom 965 Black Edition @ 4.0,ASUS M4A88TD-M/USB3,Thermaltake XP-120,Corsair TX750,SAMSUNG BX2450,Win 7 64 Ultimate,A-40 MixAmp,Audio-Technica ATH-AD700,Speedpad n52
Every day use,HP somethin somethin 4 core,found at the dump,Xubutu all the way baby!
Old September 3, 2008, 06:25 AM
yamawho's Avatar
I was in this same boat a while ago and I decided to change the mobo instead.
ASUSTeK Computer Inc.
So far the onboard video with hdmi out has been great !
Nice thing about the P5N-EM HDMI is it's matx so I was able to build a smaller system, price payed 70$.
I did find that you need to use Vista if you want sound over the hdmi however.
I used a celeron 420 which I overclocked to 2.4 ghz and 1GB of ram.
Old September 3, 2008, 02:58 PM
cdn_Madrach's Avatar
Any of the ati hd series 2400 up. I ran the 2400 pro for a while but wanted to game a liitle so I switched to a 3850. Both ran well ...3850 allows some gaming.
Intel e8400
Asus P5q pro
Mushkin Redline 4gb
Silverstone Strider 1kw modular
4870x2
Ocz Vendetta 2
Top deck Tech Station
Samsung dvd
Old September 3, 2008, 05:22 PM
Jim's Avatar
Jim Jim is offline
hey thanks guys,great info
Old September 3, 2008, 06:02 PM
JD JD is offline
HD3450 would do fine probably. Fairly cheap and there's passive versions as well.
Though I'd hold out for the upcoming low-end HD4xxx series cards. They apparently perform very well for their cost.
Old September 3, 2008, 06:42 PM
Jim's Avatar
Jim Jim is offline
cool thanks for the tip,will look into em, seems ati's got the edge in this application,yes ?
