Old September 1, 2008, 06:57 PM
Dwayne's Avatar
Yes, it seems to work fine. I have not tried the OC feature but it does read the card correctly for voltages, fan speed, temps etc. Rivatuner!
Dwayne's Rig - Asus Prime Z370-A : i7 8700k : Corsair Vengeance 32 GB DDR4-3000 : Corsair RM650x PSU : Corsair H100i V2: Fractal Design Meshify C : EVGA GTX 1080 :
HTPC - GigaByte H67MA-UD2H : i3 2100 : 8 GB Mushkin Silverline Stiletto : Antec TruPower 550W : : Corsair H100 : Sapphire HD 6670 : Corsair 650D: Kingston 60 GB SSD Boot
Tablet - Samsung Tab A 10.1"
Wife's Rig - MSI GL72M 7RDX
Old September 1, 2008, 07:26 PM
magictorch's Avatar
oh nice cant wait to try this out!!
Old September 1, 2008, 08:27 PM
Originally Posted by yamawho View Post
Does it control the fan speed on the 48xx series ?
Yes ...
Although I notice the 25% minimum that Rivatuner has is far higher than the minimum CCC uses under Auto control. It's quite loud when it's 1.5 feet from your ear @ 25%. I guess I'm just going to have to get a new heatsink and fan.
Old September 2, 2008, 05:28 AM
Dr_BenD_over's Avatar
Fallen Folder
Please take a note that currently RivaTuner doesn't support direct access to generic I2C bus and flashrom on RV770 GPUs, so generic I2C bus access based features (e.g. RADEON HD 4870 X2 fan control and monitoring) and VGA BIOS image dumping features are currently not available.
All's well that's Haswell
Old September 2, 2008, 05:32 AM
yamawho's Avatar
Originally Posted by Jmac View Post
Yes ...
Since I don't plan to overclock my HD 4870 the question is, am I better off staying with the softmod ?
Can this app is installed over the softmod ?
Old September 2, 2008, 11:00 AM
SugarJ's Avatar
I installed it over my softmod (I assume you mean changing the profile .xml file). It jacked my fan speed up to 60%. Bloody loud. Uninstalled. Sticking with 790/1100 through CCC for now, until I go WC.
Old September 3, 2008, 05:38 AM
thanks!
wait for so long~~
Old September 7, 2008, 01:05 PM
Yes Yes.. One warning to all installing Rivatuner, unless your ready for a loud sounds to scare you off, don't install it since Rivatuner's minimum fan speed % is much higher than the ATI stock.
I tried it out, and it freaked me out where did that sound come from.
  #19 (permalink)
Old September 7, 2008, 01:38 PM
1Tanker's Avatar
25%...unless you've got a Hoover hooked up to that thing, 25% shouldn't be loud at all.
  #20 (permalink)
Old September 7, 2008, 02:09 PM
SugarJ's Avatar
Maybe I did something wrong, but my HD4870 is at 30% fan now, and as soon as I tried changing things in Rivatuner it kicked the fan up to 50% IIRC. No good. The fans in these cards are LOUD. That's half the reason I'm building a WC loop.
