Old September 1, 2008, 01:21 AM
Jackquelegs's Avatar
Default Can I do this?
Right now I have a 9800GX2 on a Maximus Formula board. Since I need dual monitor display out of it, I would have to disengage SLI before I can do anything. Without SLi the FPS drops quite dramatically, and I would like to have it on. Now I'm thinking I should use the other PCI-e slot on my mobo to accommodate another nvidia card for the second display, say an 8600GT
Can it be done with 9800GX2 still in internal SLi and with 8600GT powering another monitor?
Iapetos
Zephyranthes
Old September 1, 2008, 02:04 AM
Does the 9800 GX2 not have 2 monitor outputs or am I missing something here ?
Old September 1, 2008, 02:06 AM
Yes it does have 2 monitor outputs, plus another HDMi output. However in order to have dual output on the 9800GX2, you have to disable the internal SLi that it has. I'm trying to avoid that.
Iapetos
Zephyranthes
Old September 1, 2008, 07:30 AM
As long as the video card is another nvidia it should be fine... theoretically.
Windows can be a bit unpredictable when using more than 1 card in a system. I know I built a system once that had a SLI and third separate card it worked.
Old September 1, 2008, 08:49 AM
belgolas's Avatar
it could even be an ATI card too. you can have both.
Sponsor a child!
Fight poverty.
Qoute by Perineum
"ID10T. I just BETCHA he's got 9 toolbars on his web browser right now."
Old September 1, 2008, 08:54 AM
Windows can become VERY VERY unhappy mixing two different types of driver installs.
Old September 1, 2008, 09:17 AM
CanadaRox's Avatar
I've used an X600 and an 8800GTX just fine under both XP and Vista. On XP you can install both drivers, but I didn't ever find it was necessary and the stock VGA driver worked fine for 1024*768. With Vista you can't install the ATI driver, but the stock Vista driver is much more capable than the XP one so it should be no problem as long as you don't need too high of a resolution on the 2nd monitor.
Project: Black and White
Old September 1, 2008, 09:51 AM
Supergrover's Avatar
What about one of these?
NCIX.com - Buy EVGA UV Plus USB to DVI-I/VGA Adapter USB2.0 Up to 1600X1200 Resolution - 100-U2-UV16-A1 In Canada.
I would go the 8600 route if you have it, doesnt cost you anything that way.
R.I.P.
Old September 1, 2008, 11:16 AM
It's good to hear that's it possible. I may pick up something this weekend at NCIX's saturday sale then. Thanks guys!
Iapetos
Zephyranthes
Old September 2, 2008, 05:25 AM
zlojack's Avatar
I've read that they will be releasing a new driver that allows SLI with multi-monitor support.
