Old September 2, 2008, 05:46 AM
Supergrover's Avatar
Originally Posted by zlojack View Post
I've read that they will be releasing a new driver that allows SLI with multi-monitor support.
Thats suppost to be the 180.xx drivers if I am correct, think it will be awhile yet before we see them even in beta. But yeah multimonitor support with SLI, took them long enough IMO.
R.I.P.
Old September 2, 2008, 06:26 AM
MpG's Avatar
MpG MpG is offline
I'm pretty sure that the DRM in Vista keeps you from running multiple display drivers at the same time. You might be able to get away with two cards from the same company, though.
Old September 2, 2008, 08:23 AM
if you really wanted to game while using multiple monitors you could always go full out and get one of these
Matrox Graphics - Home
i've got one with 3, 22" samsung monitors, gaming is phenominal on it, and you can use it in conjunction with SLI (which i would recomend doing anyway due to the extreem resolutions this thing runs)
kinda pricy, but worth every penny!
vista 64 on these rigs
Q9450 @ 3.5Ghz | E8400 @ 4.2Ghz
8gb Muskin Redline. | 2gb Kingston Hyperx
________________________________|_________________ ______________
EVGA 780i FTW ----\--||___||--/---- EVGA 780i SLI
Antec TP Quatro 1000W \ :==^==: / Antec TP Quatro 850W.
Nvidia 9800 GX2 X 2 SLI \|--o--|/ Nvidia 8800 GTS X 2 SLI
1X 500GB Western Digital. \_____/ 3X 150GB WD RAPTOR RAID-0
Old September 2, 2008, 11:16 AM
Dr_BenD_over's Avatar
Fallen Folder
The 180's are "supposed" to be out in the fall according to rumours.
All's well that's Haswell
Old September 2, 2008, 05:22 PM
Jackquelegs's Avatar
The issue I'm having with it is that...I have to disable SLI in Nvidia Control panel in order to enable multi monitors. I don't think I will get that option once I put in another card other than a 9800GX2, therefore I will be stuck with disabled SLi on the 9800GX2..I think
Iapetos
Zephyranthes
