Old August 29, 2008, 05:22 PM
Default AGP ATI 3850, Sapphire vs. Powercolor
Both shown on NCIX, I found a much better price on Soho Diffusion here in Montreal. The PowerColor is still not delivered and is my card of choice because of the cooling unit. This is for my HTPC and limited gaming PC which currently has an All-in-Wonder ATI X800 XT. Good as this latter card is, it does not do for HDCP (Blu-Ray and HD-DVD playback).
Having a 3.2 GHz Intel in there paired to 1GB DDR 400 MHz, I'm confident I'll be able to extend my gaming possibilities a bit.
So, I wonder how much better the cooling is on the PowerColor compared to the Sapphire. I'm not likely to overclock it. Anyone have a clue at how noisy the Sapphire could be? They both sport the same price (160$), but I'm offered the Sapphire as a readily available option. I've searched for temp issues, and found no reviews showing the matter. Perhaps the 3850 has no high temp issues.
POWERCOLOR HD3850 512M-DDR3 AGP 8x
Sapphire HD3850 512MB-DDR3 AGP 8x
Please forget the full CPU/memory/mobo/ GPU upgrade option. I've considered it and am not interested in the least bit; not for many months ahead. I'll stand the older games for a long while since I'm not that heavy on gaming nowadays.
AMD Phenom II 945
Asus M4A87TD EVO
Sapphire HD4860 1GB (a handicaped 4890)
Corsair XMS3 4GB DDR3 @1600 MHz
WD Caviar Green 500GB
Windows 7 64bit
Old August 29, 2008, 09:48 PM
tfran's Avatar
It seems so unreasonable to pay that much for a 3850 when you can get a 4850 for that, or cheaper.
Anyways, just based off of those pictures I would guess the Powercolor might run cooler. The heatsink looks somewhat better. However, that's pure speculation.
However, I would still highly suggest upgrade your system. P35's and 2gb kits of DDR2 are so cheap now it doesn't make sense to spend $160 for a 3850 when you could spend around $275 for 4850, P35, and DDR2 800. And for an extra $125 or so an E7200. You will have massive performance gains for spending a little over a $200 premium over what you're currently going to spend.
Old August 30, 2008, 02:01 PM
Well, it's still 400$ vs. 160$ and I don't want to spend 300-400$ any time soon. My plan for a full upgrade is still for about two years away. It's not much money to some, but for me it is.
AMD Phenom II 945
Asus M4A87TD EVO
Windows 7 64bit
