The sensor movement should be fine, well within the "normal" range. Do both of the core temperatures match (within a few C) or is one crazy while the other seems proper. I know a lot of the 45nm's have screwy temp sensors so that might be the issue. Also, make sure you don't have too much thermal paste, you could try remounting it as well. Only other thing I can think of is maybe an airbubble somewhere in the rad or waterblock. Try tilting your case around and see if any bubbles pop up anywhere. Good luck. 38mm fans will be better than 25mm fans with the same CFM as they will provide better static pressure. Unless he has gotten the lowest CFM fans possible, and undervolted them, that should be plenty for an 8400.
__________________ X3350 @ 3.6GHz | Asus P5Q-E |2x2GB Dominator @ 1080MHz VisionTek 4870 @ 825MHz/4.6Ghz|WD 640GB Black PCP&C 750W Silencer | HT Omega Claro X3350 @ 4187MHz |
| Quote:
(Oh and the temps for the two cores are always the same as each other in Real Temp)
__________________ CPU | Intel E6750 @ 3.6Ghz (Water) MoBo | Asus P5Q-E RAM | Corsair XMS2 4GB GPU | Diamond Radeon HD4870 PSU | Corsair620HX Case | Cooler Master 690 Damn... My E8400 died. "LOLOMGWTGdairyqueenLOLOMGBBtheQ!" -An Oxhorn Brand Medley |
| Quote:
25mm fans with static pressure can work better than a 38mm fan because there will be less of a dead spot for the 25mm than the 38mm fan.
__________________ CSE: Lian-Li PC-A70 MOB: Biostar T-Power I45 CPU: Intel C2D E8600 @ 4.3ghz RAM: 4gb g.skill pc2-8000 GPU: XFX 8800 GT Alpha Dog Edition PSU: PC Power & Cooling 750w Heatware: My Heatware |
| But good luck finding a 25mm fan that has higher static pressure than a 38mm fan with similar CFM/noise levels.
| Quote:
Some rads like more static pressure than others. I think this could be a result of the wrong fan with improper thermal paste applied. Also out of curiosity did you just throw the loop together and start using it? Or did you clean everything properly before using it?
How can it slip off the barb. Don't tell me you didn't add clamps...
__________________ Main: GA-X58-Extreme - i7 920 - TX750W - Raptor - 3Gb DDR3-1333 Triple-Channel - GTX260 SLI'ed - TRUE - P182 HTPC: M3A78-EM - 5000+ X2 - HX520W - 'cuda 1Tb - XP2-5300 2x512Mb - 9800GT - SI-128 - Prelude - Moneual 932B |
| Uhh, nope, I didn't use clamps. But I was using 7/16" tubing with 1/2" barbs, so it was tight enough.
| Thread Tools | |
| Display Modes | |
