Old August 18, 2008, 07:00 PM
Infiniti's Avatar
Default Arctic Cooling Accelero Xtreme fans
Hey all, since Anitec is being gay and still doesn't want to RMA my cooler, I was thinking of replacing the fans myself. I was wondering if I could attach two fans, either 120mm or 80mm on the heatsink with zipties or something. And if I do, should they be push, or pull?
Old August 19, 2008, 12:30 PM
Infiniti's Avatar
Anyone?
Old August 19, 2008, 12:33 PM
SKYMTL's Avatar
HardwareCanuck Review Editor
I would say zip-tie some fans to it. The extra weight should pose no problem at all.
Old August 19, 2008, 12:38 PM
Infiniti's Avatar
Okay, but 120mm fans or 80mm? And should they be push or pull?
Old August 19, 2008, 12:40 PM
SKYMTL's Avatar
Push through the fins and whatever fans fit the best on the heatsink.
Old August 19, 2008, 12:57 PM
I have a accelero s1 with a 120mm tri-cool attached to it.
works fine.
