-   -   It's here - Diamond HD4870X2 (http://www.hardwarecanucks.com/forum/video-cards/9356-its-here-diamond-hd4870x2.html)
Dr_BenD_over August 14, 2008 10:19 AM
Well, it finally arrived. 3D '06 with a 3.0GHz quad, complete waste of a card, even at 1920x1200 (still need to do a run with AA and AF maxed). 3D V, a completely different story, 1.5 time faster in performance, 2.4 times faster in Extreme. I'll run some more benchmarks when I get a higher OC on my Q6600. Hopefully I've got enough juice to get it to 3.6 at least. Probably fire up CoD4 right now and see how it runs. ( I fudged up my numbers orignally, I used scores from when I was running a P5B Deluxe for CF, not the P5Q Deluxe :doh:)
In case anybody wants to know, I'm using an Antec Truepower Trio 650W.
2x HD3870 in CF
'06 Default 16218
'06 1920x1200 14996
Vantage Performance 8403
Vantage Xtreme 2928
HD4870X2 (can't make scores public yet as it's still Generic VGA)
'06 Default 17118
'06 1920x1200 15774
Vantage Performance P12622
Vantage Extreme X6983
http://i36.tinypic.com/246lv9g.jpg I did get a screen cap of the Xtreme run
CoD4 is running at about 90fps with everything maxed @ 1920x1200 and it drops down to about 70 in heavy action. Certianly an improvement over the HD3870's
GRID Demo, 8xMSAA, 40-60fps (v-sync) again at 1920x1200
Crysis Demo
XP
Frames, Time (ms), Min, Max, Avg
113015, 2424745, 18, 83, 46.609
Vista X64
12298, 414305, 9, 78, 29.683
1920x1200, High, no AA
yycraven August 14, 2008 10:37 AM
What was your score on 3D06 and 3D V. lets see some pics
..'Ant'.. August 14, 2008 12:48 PM
Id like to see the card pics. :P
Dr_BenD_over August 14, 2008 01:03 PM
Unfortunately, I only had my camcorder home when it got here, and it doesn't take single frames. It's as pictured at Diamonds site Diamond - ATI Radeon™ HD 4870 X2 PCIE 2048MB GDDR5 Video Card
Popped into the office and got my camera, and an installed pic
miggs78 August 14, 2008 02:28 PM
That card is good, but you know us system builders always have complains, like I have one stupid one lol. I was hoping they put both PCI-E connectors next to each other for cable management, both are apart, and it even looks weird.
Dr_BenD_over August 14, 2008 02:55 PM
A lack of real estate on the board, they're at either side of the fan shroud.
miggs78 August 14, 2008 02:58 PM
Na I understand, it just wasn't possible, I'm sure they thought of it when designing the pcb/card, sometimes you have to sacrifice for an outstanding card!!.
Dr_BenD_over August 26, 2008 03:42 PM
2 week update!
If you need to disable CF for old games, like Ravenshield or Desert Combat, just disable Catalyst AI, as with 2 seperate cards, one core gets disabled.
Scary moment last night. I decided to fire up Bioshock, and it went to artifact city, then locked solid. I rebooted, confirmed my CCC settings, fired up Bioshock again. Same thing. So I rebooted, checked my CCC settings and fired up the Crysis demo, which I know works, artifacts, LOCKS. WTFH!!!!!!!!! Reboot, check CCC settings yet again, fire up Crysis, and as it starts to artifact, I alt-tab back to windows and open the CCC, to find at Overdrive has been enabled and has upped my freaking clocks!!. Now I had played with the auto tune a couple days before, but it HAD been disabled afterwards, and it certianly hadn't been enabled when I started Crysis, the only profile I have saved is from BF42 on my 3870's, and it certianly didn't use an OC. More CCC weirdness it would seem.
Iamcanadian7 August 26, 2008 04:01 PM
I had the same issue with my pair of 4870x2's. I tried turning them up to 800 core through CCC overdrive and everything started artifacting. I eventually had to wipe the drivers out and start fresh but its now running smooth as butter.
Oversized Rooster August 26, 2008 05:27 PM
It looks like you need a new CPU. You're being bottlenecked...
With dual 4850 cards in CF, I broke past 15000 points in Vantage Peformance. I can't see why with dual 4870 GPUs you don't blow past this.
