Old August 12, 2008, 03:30 PM
Scart's Avatar
Default 3870 Crossfire
I have a Sapphire 3870 and I was wondering if it would be better to buy a second one and run in crossfire or buy a 4850 and eventually get another and run them together.
I can't really find any reviews comparing the two card's crossfire performance to figure out price/performance, but I will keep looking.
Old August 12, 2008, 04:32 PM
Killswitch's Avatar
I found this -> LostCircuits, Video Guide
I guess depending on the price and what games you play you could get another 3870. You'll also be able to get your moneys worth from your current 3870. I'd say if you decide to go with 3870's in crossfire, try to find a used one for around $100 or so. Otherwise bend over, get out the lube, and sell it off to upgrade.
Old August 12, 2008, 04:42 PM
Dr_BenD_over's Avatar
Fallen Folder
Crossfired HD3870's are still a pretty decent setup if you have a good motherboard. What would they be running on?
All's well that's Haswell
Old August 12, 2008, 11:14 PM
Scart's Avatar
not sure my current board is sli but i'm trying to sell most of my parts and upgrade. Would probably be a maximus formula or if i go really crazy a rampage formula.
I also currently have a corsair HX520 so would i need to upgrade power supply as well?
Old August 13, 2008, 06:23 PM
Killswitch's Avatar
SLI = nVidia. ATI = Crossfire.
What do you currently have for a motherboard?
Old August 13, 2008, 11:49 PM
Scart's Avatar
I know sli is nvidia, thats one of the reasons why I want to upgrade.
I have a M2N32-SLI Deluxe but If I do manage to sell my stuff I may get a maximus or rampage formula.
Old August 17, 2008, 05:14 PM
Killswitch's Avatar
Ah I see. I misunderstood your other post.
Ever consider getting an AM2+ board for CF? You could carry over your current CPU and RAM which will save you some cash for now.
