Old August 8, 2008, 09:47 PM
Originally Posted by belgolas View Post
it all depends but performance wise the 4850 CF will be a good bit faster but if money is tight then 9600 GT SLI should be more then enough.
Just what I said but in a paragraph, thanks belgolas, I second that
Old August 9, 2008, 06:43 AM
Dr_BenD_over's Avatar
Fallen Folder
Crossfire is like... um, err, uh... Like SLi, er....
Even though I run CF, and have run Sli, I can't support either, aside from benchmarks, they're both a pain in the ass when it comes to gaming.
All's well that's Haswell
Old August 9, 2008, 12:50 PM
yycraven's Avatar
NCIX has the 9600 GT for $104 right now.
NCIX.com - Buy BFG GeForce 9600GT OC 675MHZ 512MB 1.8GHZ DDR3 PCI-E Dual DVI-I HDTV Out Video Card - BFGE96512GTOCE In Canada.
So if you went this way
eVGA 750I FTW 189.99
BFG 9600GT 104.99
E7200 140.30
Total $435.28
eVGA 750I 189.99
BFG 9600GT 104.99
E8400 $198.36
Total $493.34
If you went
P5Q-E $178.84
Diamond $204.99 X2 = $409.98
E7200 140.30
Total $729.12 with the E8400 Total=$787.18
So if you got one single card the GTX 260
NCIX.com - Buy EVGA E-GEFORCE GTX 260 Superclocked 602MHZ 896MB 2.052GHZ GDDR3 Dual DVI-I HDCP HDTV Out Video Card - 896-P3-1262-AR In Canada.
eVGA 750
GTX 260
E8400
total is $678.34
if your a little tight on money , I would go with one of the top two.
but that's just my opinion.
Old August 9, 2008, 02:45 PM
magictorch's Avatar
Sky did run into issues with cf 4850's but I don't know the details of why, what or how.
The 4870's are really good in cf, really good. I am sure any issues with the 4850's can be sorted out.
If you can Id get 4850cf and buy NVIDIA when they have something fresh for the table.
Old August 9, 2008, 09:50 PM
yycraven's Avatar
So do you know what your going to get.
Just wondering if you decided on anything yet.
Old August 12, 2008, 10:17 AM
tfran's Avatar
I have 96's SLI'd on 750i ftw and they're pretty good from a price/performance POV. The % gain from the 2nd card is higher than average for SLI. They also run ridiculously cool. In an antec 900 I don't think I've ever seen them go above low 40s. It runs dmc 4 on 1920x1200 max everything and I've ever seen a hiccup. BTW also running e8400.
One thing to note: I seem to get fairly frequent driver irql BSOD's. I've yet to figure out if it's mobo/graphic related though. I've never had any BSOD's in xp however. (On that note has anyone heard of something similar with similar hardware?)
IMO I think the 2nd 9600 would be enough and save the extra money for a Nehalum build. By that time I'm sure the 5000 and 300 series will be out and both 9600 and 4850 will be outdated by a single $200 card.
