Originally Posted by Jmac One thing to keep in mind, especially if you're on a tight budget and/or inexperienced, is that the pre-OCed versions are warrantied at those speeds whereas the reference models you flash and overclock yourself will not be (nor will the aftermarket cooler be covered). |
This is pretty much the most important point. If you're constantly going through hardware and don't care about losing a warranty or even bricking a card then there's really no reason to buy a pre-oc'd card just for gaming. OC'ing a modern graphics card is not difficult by any means, especially with flasing. If this is your one graphics card that you need to keep for an extended period of time and you really want that extra speed then it's probably worth your while to just buy the pre-oc'd card.
