Old August 2, 2008, 05:44 PM
Jim's Avatar
Jim Jim is offline
Default 4870x2 , psu requirements
just wondering if my psu will cut be enough for this video card ?
Shooter-Gigabyte GTX 660 Ti OC,G.SKILL Ripjaws 8 gigs DDR3-1600, Phenom 965 Black Edition @ 4.0,ASUS M4A88TD-M/USB3,Thermaltake XP-120,Corsair TX750,SAMSUNG BX2450,Win 7 64 Ultimate,A-40 MixAmp,Audio-Technica ATH-AD700,Speedpad n52
Every day use,HP somethin somethin 4 core,found at the dump,Xubutu all the way baby!
Old August 2, 2008, 06:28 PM
yes it will corsair psu are made my seasonic...
Old August 11, 2008, 11:07 PM
darksideleader's Avatar
yep, may i ask what size monitor you have?
My new baby
Intel Core i7-3820 - Asus Rampage IV Gene x79 - Corsair H60 - Kingston HyperX 4x4GB DDR3-1600
Kingston SSDNOW V+200 120GB - Western Digital Caviar Black 1.5TB
HIS Radeon HD 7970 - ASUS VW266 25.5" 1920x1200 LCD
Silverstone TJ08B-E -
Corsair TX750V2
Windows 7 Home Premium x64
Ducky Keyboard DK9008
Logitech G500
Razor Vespula
Old August 11, 2008, 11:13 PM
Now what's a power supply to do with a monitor.
I'd say a good 750W PSU should be able to handle, or you could get a 1000w just to be future proof. I guess SKYMTL on his recent review of 4870X2 used a 1000w Corsair.
Old August 11, 2008, 11:40 PM
burebista's Avatar
Plenty of room with HX620. But not your PSU will holding you back, CPU will do.
And about resolution if he don't have a 24" or more this VGA is a waste of money.
Old August 12, 2008, 06:08 PM
Phobia's Avatar
woot woot i love my 1000hx
(whitty saying to be plagiarized at a later date)
Old August 12, 2008, 06:41 PM
geokilla's Avatar
Your PSU should be sufficient enough. However, like what others said, your CPU will be bottlenecking the card.
Also, like the others asked, what resolution do you game at? If you're going to pick up a 4870X2 but game at only 16X10, then that's a waste.
Old August 17, 2008, 04:25 PM
Jim's Avatar
Jim Jim is offline
sorry guys been away from the forms for a week(work) anyway I plan on a 24" screen 6 months down the road,hows my cpu a bottleneck it's @ 3.3 ? , current monitor only does 1280x1024 wanted to buy a vid card with longer life span ( in terms of useability)
thanks
Old August 17, 2008, 04:46 PM
My E3110 @ 3.96 GHz still holds my HD 4870 back in some applications @ 1920x1080 ...
3.3 GHz is definitely going to be a bottleneck in games that make heavy use of the CPU like RTSs or physics-heavy FPSs ...
As for PSU requirements, I'd say a high-quality 620W like you have will probably be fine, although it's borderline. My medium-quality 900W PSU still drops down to 11.65V (12.06V idle) under full load w/ my HD 4870 ...
Old August 17, 2008, 05:11 PM
Jim's Avatar
Jim Jim is offline
wow thats informative,only have 2 games in mind cod4 & cod world at war, available upgarde budget is about $700 cnd , since my crt monitor only goes to 1280x1024 guess i could get the x2 now , run it as best i can and get a e8600 later(which i understand hit 4gig easy) least thats one idea
