Old August 1, 2008, 03:49 PM
andynerd's Avatar
Default can i do this?
If i have a dual or tri sli supporting mobo can i use two 9800gx2 sli'ed? Will it take advantage of the 4 gpu's?
Old August 1, 2008, 05:03 PM
Cptn Vortex's Avatar
Apparently SLI 9800GX2's is not too good, actually worse in some games. I just use 1 and it is more than enough power for modern games.
The Vortex H20
MSI Z77A-GD65
Intel i7 3770K @ 4.6GHZ 1.28v
Galaxy GTX 680 @ 1241MHZ
8GB Mushkin Blackline 1600MHZ 9-9-9-24 1.5v
Asus Xonar Essence STX
OCZ Z-Series GOLD 850W
2 x 128GB Corsair Force GT SATA3 SSD RAID0 :)
Acheiva Shimian Q270 Lite 2560x1440
Benq W500 Pojector.
Watercooling:
EK Supreme HF, EK FC GTX 680 Block, MCR320+Gelid Silent 12 Push/Pull, DD Pump, EK Multioption 100ml Res, EK Coolstream XT 220 RAD Gelid Wings Push/Pull.
Old August 1, 2008, 05:23 PM
andynerd's Avatar
aww but you can get 50fps on crisis on very high
Old August 1, 2008, 05:36 PM
Default Reply
I'd just get a GTX260 or a GTX280. Both have more overclocking potential. But yes, it's possible to have Quad SLi. Also you could consider an ATi HD4870.
Old August 1, 2008, 05:46 PM
andynerd's Avatar
i am not a big overclocker even though i am planning on getting an old computer to overclock (as my first project)
Old August 1, 2008, 06:33 PM
b1lk1's Avatar
If you have a 30" LCD with 2650X1600 resolution or higher you could run Quad SLI, otherwise it is senseless, especially if you're not overclocking the CPU to the max.
MY HEATWARE
Old August 1, 2008, 06:35 PM
andynerd's Avatar
how i still get increased performance and the graphics card should be good for another 4,5 years with new drivers (not saying by the end of 5 years i will be able to play the best games pfft ya right :P)
Old August 1, 2008, 07:11 PM
4850 and overclock the SNOT out of it LOL.
The Vortex H20
MSI Z77A-GD65
Benq W500 Pojector.
Watercooling:
Old August 1, 2008, 07:20 PM
andynerd's Avatar
lol :P hmm well maybe i will use my old computer overclock the P4 from 2.4 ghz to 4 ghz and get a card and over clock the hell out of the ENTIRE THING
Old August 1, 2008, 08:21 PM
In 5 years your setup will probably be equal to a GeForce 4 Ti4200-8x AGP :D
Well ok maybe not :D but there again maybe in 5 years you won't need a graphics card with your new 12 core and 80 core CPU :D
