Old April 14, 2007, 12:13 AM
Default 8800 GTX poor FPS
Ok, I went and sold my condo and bought the 8800 GTX. I am not totally disappointed as it runs my games a lot better then my X800 GTO2 but truthfully I was expecting it to kick the shit out of what I was getting with my X800. FarCry for instance runs a lot better/smoother getting around 80/110 FPS, COD2 I get only 35/40/50/maybe 60. Half Life DOD S I am getting roughly the same 30/40/50/60 depending what angle I face.
I need some feed back from some of you guys out there who are running an 8800. What FPS are you getting running these game in particular?
I know I did to do a format reinstall in the worst way I will get on to my back ups then do a reinstall.
Anyway I will keep searching for answers. BTW Have any of you guys seen this? Legit Reviews - GeForce 8800 GTX Resistor Change in Pictures - One Resistor Value Change Made the 8800 GTX Work I'm not sure (as I need a magnifying glass) but I think my card has the shitty resistor.
Thanks
Corpus
EVGA 680i SLI 122-CK-NF68-A1,
Intel C2D E6850, EVGA 8800GTX,
OCZ Reaper PC2 8500, Ultra X3 1000W fully modular PSU,
1 Primary Raptor X 150 gig + 2 150 gig Raptors in RAID 0,
Swiftech H20-220 Ultra with a Stealth GPU water block,
Dell Ultrasharp 2407WFP-HC 24" monitor,
Lian Li V2000 Plus Case slightly modded,
Steelseries Akari Laser Gaming Mouse, Razor Tarantula keyboard,
AuzenTech Prelude Sound Card,
Pioneer VSX-1016TXV receiver with Bose 301's,
AKG K240 Phones, Blue Snowflake USB Microphone.
Old April 14, 2007, 12:20 AM
werty316's Avatar
What resolution are you running your games at?
The 8800GTX is CPU dependant.
The different resistor issue was in the pre-production batches which was small so unless you got a review sample chances are your 8800GTX is fine. Only sure way is to check if your 8800GTX has the wrong resistor based on the link you posted.
If you can see Chuck Norris, he can see you. If you can't see Chuck Norris you may be only seconds away from death.
Old April 14, 2007, 01:10 AM
Do you run a 8800 GTX or GTS? If so what kind of FPS are you getting from the games mentioned? If you have them that is.
Old April 14, 2007, 05:31 AM
Babrbarossa's Avatar
I'd guess you're CPU bottlenecked. I'll check my COD2 fps in a bit here.
Old April 14, 2007, 09:04 AM
b1lk1's Avatar
That videocard is horribly bottlenecked by that CPU. You would need a Core 2 Duo running over 3GHz to ease it at all. An 8800 GTX is too much for your older system. If you are gonna stick with your AMD setup, you need to overclock it as far as possible to help. If you can get it to 2.9-3GHz it will help, but any way you look at it, it will always be bottlenecked in an AMD system.
DAILY: MSI 970 Gaming/FX6300/16GB Corsair DDR3/ASUS CU II R9 270 2GB/128GB SSD+750GB HDD+2TB HDD
Old April 18, 2007, 08:38 AM
That just Suxorz!!
Thank for the replies.
CM
Poor Richard Zednik Killswitch Hockey 2 February 11, 2008 02:55 AM
Poor picture quality from TV tuner Sharkylegbreaker HTPC Systems & Software 7 November 29, 2007 03:03 AM
-12v Rail and Poor Performance kcksteve Troubleshooting 11 September 9, 2007 08:08 PM
pcvillage (pcvonline.com) poor merchandise? Schwarz CPU's and Motherboards 6 May 17, 2007 10:16 AM
DOH! My poor truck cdn_Madrach Off Topic 12 April 19, 2007 12:27 PM
