Old July 31, 2008, 09:10 AM
Default Helap!
Hello, i was wondering if 2x eVGA 8800 GT 512mb graphics cards can be compatiable with the Asus Rampage Formula .. im not sure and i need help(sorry if this is a noob question)
thanks for answering back
Old July 31, 2008, 09:17 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
No, only one would be compatible as this board only supports Crossfire (ATI's dual card solution).
Old July 31, 2008, 10:09 AM
Thanks for the prompt reply, but i have another question -> The 2 eVGA 8800's could be compatiable with a eVGA nForce 780i SLI right?
Old July 31, 2008, 10:22 AM
Yes, they would.
Old July 31, 2008, 02:04 PM
Default Reply
Yes, they would be compatible. But if you were to get an SLi board, I'd get the EVGA 750i "FTW Edition". Or just buy a Crossfire board.
Old July 31, 2008, 04:53 PM
Thank you all for your help .. and what's the difference between the 750i and 780i, which one is better in terms for gaming?
-thanks everyone
Old July 31, 2008, 05:11 PM
SugarJ's Avatar
Unless you are running an SLI system, you probably wouldn't see a difference.
The 750i runs 2 Nvidia cards at x8/x8, the 780i does it at x16/x16.
Old July 31, 2008, 05:14 PM
SLI really is a waste of money these days.
If your running a single monitor under 24" go for something like the 9800GTX but if your running a single 24" just run a GTX280.
Old August 2, 2008, 01:51 PM
Retro's Avatar
What he said ^
I prefer to stick with Intel based boards, a P45 mobo like the Asus P5Q Deluxe or Pro and a single GTX280 would rock
Latest build:
i5 750@3800MHz 20x190@1.38125v
Noctua NH-U12P/NF-P12
4G GSkill DDR3 2000 Ripjaws
Asus P7P55D-Pro
2x EVGA GTX275 in SLI
PC P&C 750 Silencer
Cuda 500
Antec 902
W7 64 RTM
Old August 2, 2008, 03:15 PM
Thank you all for your replies again. So if i had a nForce 750i FTW and a eVGA GTX 280 would that be a good setup?
- Thanks again.
